No, your battery doesnt know if it is being charged by your alternator or a battery charger but why do you want to charge it to full capacity prior to putting a battery tender on it?
I'm with Boo2You. I put my Sportster on the trickle charger after a LONG time without riding and after a day or so of charging the light went green and i've had no problems.
Originally Posted by soos
Why? A battery tender will bring it up to full charge and then cycle to maintain the charge.
I thought a battery tender was just for maintaining the battery and wouldn't being it up to full charge if it was at 50% charge.
You only need the tender. It's a question of how fast it'll charge - and that's a question of how depleted the battery is and what tender you have (the Tender Jrs put out lest amperage than the regular tenders).
the battery tender was designed to be a small trickle charger, it will bring your battery back into shape without any concerns. i would not use a car type battery unless it's one of the newer ones with the trickle feature. i'd trust the battery tender to bring your battery back up. i use mine on my corvette during the winter months while its too cold out to go cruising in it, and it works just fine with a car battery too. i alternate, a few days on the car, a couple on my riding mower, a couple on my streetglide. it won't hurt anything at all. i like the pigtail so you can attach one setup on each vehicle needing a trickle through winter.
