update radio
Old Jul 30, 2006 | 09:55 AM
kdietz's Avatar
kdietz
Default RE: update radio
Follow the directions and make sure you record at 8X or slower......I'm speaking from experience!
Old Aug 2, 2006 | 05:22 PM
HD Jake's Avatar
HD Jake
I did mine upgrade today
Worked OK, but the radio did not power don and turn back on as it stated in the instructions.
I waited 15 minutes and then turned the radio off for a couple of minutes and then back on and then ejected the CD and put it back into Diag Mode, it said the software was 8.0 so I guess I am set
Old Aug 2, 2006 | 05:28 PM
gunrunner's Avatar
gunrunner
Is this something that would need to be done on a 07?
Old Aug 2, 2006 | 06:04 PM
FireHawk's Avatar
FireHawk
You could get it into diag mode and see what version of the software is to tell.
Old Aug 2, 2006 | 06:08 PM
jjsanta's Avatar
jjsanta
To get into update mode hold down two of the "softkeys" while turning the ignition switch to the accessory position. Once in that mode, I think it's button #4 that will display the version info.
Swampfox1949
Feb 15, 2014 05:11 PM
Steel Billet
Aug 1, 2011 10:02 PM
FFeric
Apr 1, 2009 04:55 AM
Bullitt772
May 20, 2008 10:57 PM
chubbynj
Aug 13, 2006 11:54 PM
