OK...my dealer mentioned it and showed me one. He said if you have lowers, that it was the last spot to install a baffle to eliminate that slim area of remaining wind. Some here are saying it won't fit with lowers installed.
This baffle will, the ones mounted to the outside of you forks will not, they will dig into your lowers.
The air baffle is in between the forks. If the forks won't hit the lowers, it would make sense the baffle won't hit as well right??
It will fit. It must be part of the SG/RG transformation that was left out from the true RG's.
The ones that dowhat is talking about are the chrome or clear deflectors mounted on the side of the forks.
I affectionately call the "Elephant Ears"
My '02 Ultra did not come with one so I put the chrome one on. Couldn't tell much difference with the wind but noticed big improvement in acceleration. I also increased my fuel economy by 8 miles per gallon. Yes, I'm just kidding.
My '08 Road Glide came with the black one.
Just my opinion but it does look like it will force more air toward the engine.
