Installing Floaters
Old Jul 21, 2006 | 12:39 PM
jmxp's Avatar
jmxp
Default Installing Floaters
Does the wheel have to come off to install floating discs up front? My floaters will be here today, and I need to know if I have to go dig my lift out of storage.
Thanks,
J
Old Jul 21, 2006 | 01:17 PM
stsltd's Avatar
stsltd
Default RE: Installing Floaters
Well - yeah
Don't forget the torque wrench and loctite when reinstalling the bolts - don't want the discs to come loose in the future....may want to check Harley - they have a chrome bolt kit you might want to look at also
Old Jul 21, 2006 | 01:42 PM
skos's Avatar
skos
unless you are realy realy good.
Old Jul 21, 2006 | 01:49 PM
eddybo69's Avatar
eddybo69
Go get the lift. I cant say why floaters are not standard on every bike, but they should be.
Old Jul 21, 2006 | 02:34 PM
RenoGlide's Avatar
RenoGlide
Secure the bike on the lift
Remove the wheel
Find an old tire or crate to set the wheel on .. remove rotors
Inspect everything you can see - better to catch something now than later
Spray brake cleaner into the bolt holes & clean it out
Install rotors & NEW bolts & red Loctite - torque to specs
Good time to upgrade the stock brake pads to EBC Kevlar or Lyndall Racing Z or Gold Pads
Grease the axel a little & reinstall wheel - torque everything to specs
Pump up the brakes & check rotation - a little brake drag is normal
Reinspect everything before dropping it back down
Recheck the brakes by sitting on it & holding the brakes in, rocking the bike forward
Take a short test ride
Working with brakes is no place for short-cuts
Reno
www.FastAire.com
Old Jul 21, 2006 | 02:51 PM
bountyhunter's Avatar
bountyhunter
If you are VERY carefull you should be able to install the new floaters without a lift and there will be no need to take off the wheel or brake calipers.
Old Jul 21, 2006 | 04:21 PM
Inforit's Avatar
Inforit
ORIGINAL: eddybo69
For a Harley owner like yourself it is hard to believe you are suprised . Like everything else including handlebars, etc because they can make a lot more money.
Old Jul 21, 2006 | 04:26 PM
wldhogn's Avatar
wldhogn
And we all know money is what it's all about!
Old Jul 21, 2006 | 04:33 PM
jmxp's Avatar
jmxp
ORIGINAL: RenoGlide
Do you happen to know what the torque spec is? I know, get the manual, but I don't have it yet. I'll get one.....but for now, do you know?
They just got here. I'm on my way out to get some red loctite and my lift.
J
Old Jul 21, 2006 | 04:42 PM
RenoGlide's Avatar
RenoGlide
My handy TQ guide is for a 1997- 2002 but I think its the same for all later years
16-24 foot pounds
I do mine in a cross pattern starting at 10 lbs then 22 lbs ... but Im kinda **** about these things
Reno
