Installing Floaters
Old Jul 21, 2006 | 04:44 PM
jmxp's Avatar
jmxp
Default RE: Installing Floaters
Cool thanks. 16-24..hrmph, pretty wide range. I'll do 24.
Thanks guys! This place is like having my own "trustworthy" mechanic hotline for FREE!
Thanks again,
J
Old Jul 21, 2006 | 05:47 PM
stsltd's Avatar
stsltd
I would expect that when you are done you will re read your original question and chuckle to yourself -
As noted - don't forget to secure the bike to the lift - once you pull the front wheel, the bike may no longer be balanced - boom...
Good luck - a very good update to your braking system - plan on doing mine in about a week
Old Jul 21, 2006 | 07:32 PM
jmxp's Avatar
jmxp
Man, dumbass attacks from every direction
1) You don't HAVE to take the wheel completely out, I was able to give a pump or two on the lift, enough to lower the wheel and remove the discs, but obviously the axle has to come out, so a lift is necessary.
2) I ordered the wrong gd'd part. Thankfully Jenni at Bengy's is very helpful and will get the correct parts out to me asap. I just have to ship these back.
Anyway, I figured since I'd gone this far, I'd see if the rotor swap worked since I had both rotors off anyway, and, no kidding, it worked.
Get a little squeal while backing up, but they're dead silent while moving foward.
So...lessons learned.
Thanks for the responses.
Old Jul 21, 2006 | 10:07 PM
DI75's Avatar
DI75
I just put mine on real tight two years ago and they are still there!!! I hope!!!
Lilman
Aug 11, 2014 12:23 PM
dupmaronew
Apr 20, 2014 08:11 PM
TedMan
Jun 14, 2011 07:06 AM
trip20
Aug 3, 2010 07:16 PM
Jonny Cannon
May 2, 2009 06:34 AM
