regearing 09 roadking
Old Feb 1, 2010 | 01:57 PM
CROCKETT's Avatar
CROCKETT
Default regearing 09 roadking
Has anybody regeared an 09 roadking? Would like more torque, and what will it effect like cruise? shift light? Also what gears would you use?
and what is the stock gear ratio? Thanks!!
Old Feb 1, 2010 | 02:07 PM
kingkingking's Avatar
kingkingking
Just downshift. Its cheaper.
Old Feb 1, 2010 | 03:34 PM
nvsteve's Avatar
nvsteve
What mods have you done to your motor so far?
Old Feb 1, 2010 | 05:17 PM
CROCKETT's Avatar
CROCKETT
None yet, It's gutless from take off with passenger, and alot of the roads are 55, so i would like to get away from that sorry fifth gear whine!!
Old Feb 1, 2010 | 07:40 PM
FastBagger07's Avatar
FastBagger07
I put the 30T comp. sprocket from EvoIndustries on my '09 RoadGlide and love it.Lost my 6th gearlight, cruise still works fine.
Old Feb 1, 2010 | 07:48 PM
dog155's Avatar
dog155
When you gear them for quicker stop light to stop light perf,it hurts your cruise rpms unless you go with complete gearbox change.
Old Feb 1, 2010 | 07:58 PM
1931jamesw's Avatar
1931jamesw
I would go with some motor upgrades and forget regearing. Start with an exhaust, air cleaner and fuel management system. I think you'll be much happier.
Old Feb 2, 2010 | 04:58 AM
grbrown's Avatar
grbrown
Thumbs up
Do you need to do that often with your monster?!
Harleys have been over-geared for at least 20 years, the latest models even more so. I fitted a SE 21T sprocket kit to my Dyna, replacing the 25T compensator, which increased torque at the rear wheel by 19%. That is the cheapest way to tune a Harley!
For a touring bike that might be a bit extreme, but if you fit a 30T crank sprocket to replace the stock 34T you will achieve a 13% increase in torque. Engine speed at any given road speed will be increased by the same amount, so if you like to cruise at say 3,000rpm, to travel at the same road speed you will need to use 3,400rpm.
Old Feb 2, 2010 | 03:10 PM
kevin6803's Avatar
kevin6803
I thought I needed lower gearing on my 2009 also. Then I found out the 2009's already have an extra 2 teeth on the rear pulley. It seemed like I instnatly had more torque. If that doesn't work, I agree with the earlier poster to add pipes, stage 1 first. Pipes might take care of the whine also.
harley1425
Jul 9, 2009 10:35 AM
YT
Mar 9, 2009 03:24 PM
HDUltraRider
Vendor For Sale Classifieds
Dec 28, 2008 05:17 PM
FLHXXHLF
Nov 26, 2008 06:41 PM
FLHXXHLF
Nov 24, 2008 10:07 AM
