Engine compression
Old Feb 2, 2010 | 07:55 PM
B88's Avatar
B88
Default Engine compression
Does anyone know how many lbs of compression a heathy 96 ci should show? Thanks
Old Feb 2, 2010 | 10:31 PM
hog-doc's Avatar
hog-doc
150-200, but its going to depend on your particular build, affected by cam timing, LSA, duration, ect.
175-190 would be right in there!
Old Feb 2, 2010 | 11:55 PM
mtclassic's Avatar
mtclassic
elevation also plays a role. you loose ~3% per 1000'
Old Feb 3, 2010 | 08:50 AM
B88's Avatar
B88
Thanks for the info. Heading into the garage right now to check it out. Got a lot of oil blowing out of the in take and it isn't over filled. Not a good thing.
Old Feb 3, 2010 | 12:23 PM
shootist's Avatar
shootist
Default engine compression
I have 07 Street Glide, stock with stage one, dresser duals, just put 255 cams. Before the work done my compression test was 160 on both cylinders. I'm in Logan, UT about 4500 el. and I have 28000 miles on bike. Pocatello, Id. Harley shop did a dyno last April it was 73HP and 84 tor. Pocie is 4450 el., Mine also has a TFI fuel enhancement on it.
I haven't done a new dyno yet. Too cold here. What do you think about the 160 compression Hog-Doc. You must be near my area.
Old Feb 3, 2010 | 12:26 PM
mtclassic's Avatar
mtclassic
sounds about right.
Old Feb 3, 2010 | 01:14 PM
petemac's Avatar
petemac
How do you test engine compression? Pull the spark plugs and use something to measure the pressure?
Old Feb 3, 2010 | 01:31 PM
PistonPuller's Avatar
PistonPuller
If you are trying to determine cylinder compression alone, do a leak down test instead of compression test. Compression test will also take into account starter, or even battery conditions. Leak down test will isolate the cylinder compression only
Old Feb 3, 2010 | 01:33 PM
PistonPuller
Yes. Use a compression gauge
Old Feb 3, 2010 | 01:38 PM
mtclassic's Avatar
mtclassic
leak down won't tell you what your ccp is just tell you how much leakage you have..
To do a proper ccp you need a fully charged battery, remove the aircleaner hold the Throttle wide open (on carb hold the slide up) ground both plugs and turn it over until the guage stops climbing.
