Engine compression
Old Feb 3, 2010 | 02:30 PM
Ultra110's Avatar
Ultra110
Originally Posted by mtclassic
leak down won't tell you what your ccp is just tell you how much leakage you have..
To do a proper ccp you need a fully charged battery, remove the aircleaner hold the Throttle wide open (on carb hold the slide up) ground both plugs and turn it over until the guage stops climbing.
Old Feb 3, 2010 | 03:53 PM
hog-doc's Avatar
hog-doc
Originally Posted by BennieSG
If you are trying to determine cylinder compression alone, do a leak down test instead of compression test. Compression test will also take into account starter, or even battery conditions. Leak down test will isolate the cylinder compression only
Leak down is only half of the tests, you must do both leak down and compression. HOT to get an acurrate measure!
Old Feb 3, 2010 | 03:59 PM
PistonPuller's Avatar
PistonPuller
OK. I am out voted here. I always thought that a leak down test was a better way to determine if the rings were going bad...along with valves and seals. But I am not an expert. So how about compression test, and if you get low reading then leak down? But if you got readings within range then no need for leak down?
Old Feb 3, 2010 | 07:50 PM
nytryder's Avatar
nytryder
Just as important is that the compression of both cylinders are within 5-10 lbs of one another. Personally I prefer a 5 lb or less differential.
Old Feb 3, 2010 | 07:53 PM
hog-doc's Avatar
hog-doc
Compression test first, then leak down...............HOT, cold motor #'s dont give you the real story in there!
Old Feb 3, 2010 | 09:02 PM
Dalton's Avatar
Dalton
Compression test will tell you if something is wrong. Leakdown test will help you identify if is is rings, or valves
Old Feb 3, 2010 | 09:31 PM
imrotton2's Avatar
imrotton2
if compression is low,,, put a little oil in sparkplug hole .. ,check comp again,, if its higher, its indicates rings...if it didnt raise the compression , tends to be valve related
Fullcircle
Mar 28, 2019 09:38 PM
jackinthebox
Exhaust System Topics
Dec 20, 2011 02:33 PM
FLHRCI2000
Feb 14, 2011 11:03 AM
XMA
Sep 18, 2010 01:41 PM
da_king96
May 10, 2006 01:39 PM
