I want to remove the stock seat on my Ultra Classic to install a Battery Tender charge wire and adjust the backrest mount back a little. What kind of screwdriver do you use to get into the tight area where the rear mounting screw is? I've got big hand and it's difficult to get both of them under the tour-pak at the same time.
Did you check to see if a charge wire is already connected? After I read some posts here, I looked at my RK and found I already had a connection installed by the dealer just beneath the right side cover.
There was no charge wire that I could see.
I feel a little silly now that I got the seat off without a problem. I was thinking the new Ultra Classic were going to be like the '03 I had. Where the screw holding down the backend of the seat was way under the tour-pak. This one was right at the front side and easy to get to.
