won't start??!!!!!
Old Feb 4, 2010 | 06:00 PM
tekeum's Avatar
tekeum
Default won't start??!!!!!
my bike won't start I took it apart for paint & powder. new monkey bars. I got the bike most of the way back together to the point where I can test my wiring job well every thing works but it won't start. when I hit the run button the fule pump starts and primes but when I hit the start button nothing it is in nutral alarm did go off afew times until I put a new battery in the fob . I don't know what to do. is there a way to buypass the start button to see if that is the problem. I hate electrical stuff. any ideas would help.
Old Feb 4, 2010 | 06:15 PM
dawg's Avatar
dawg
Did you have to disassemble any connectors with the wiring pins, etc. when you took the bars off? Could you have crossed a wire? Electrical crap sucks to chase down, but you're gonna have to go over everything you did.
Old Feb 4, 2010 | 06:19 PM
Navy Mustang's Avatar
Navy Mustang
I'm with Dawg. Take your time, think about everything you disconnected during the disassembly process. If your fuel pump's priming the problems doesn't sound as if it's in the "run" circuit. Sounds like the actual "start" circuit has no power. Could be the alarm cutting power to it, could be an open wire/connector/fuse. Nothing serious I bet...
Old Feb 4, 2010 | 06:33 PM
tekeum's Avatar
tekeum
yes I had every wire in the bars un pluged I will have to go through evreything.
Old Feb 4, 2010 | 06:35 PM
dawg's Avatar
dawg
I'm guessing you may have screwed up a pin location then if you took the connectors apart. Take your time and check every connection that you touched/took apart.
Old Feb 4, 2010 | 06:46 PM
2011 Road Glide Ultra's Avatar
Start by opening a gallon of Patience - I hate electrical!
Old Feb 4, 2010 | 06:54 PM
tekeum's Avatar
tekeum
there are only 12 wires on that side to look on the bright side
Old Feb 4, 2010 | 06:57 PM
7125's Avatar
7125
pull the clutch in and see if it starts switch for neutral
Old Feb 4, 2010 | 07:31 PM
tekeum's Avatar
tekeum
I tried that did not work.
Old Feb 5, 2010 | 03:11 PM
tekeum's Avatar
tekeum
Default Up date!!
got the bike started mixed up 2 wires it took me 15min to get it sorted out. thanks for the suport.
