Changing Handlebar switch Housings
Old Feb 4, 2010 | 07:24 PM
madmatt500's Avatar
madmatt500
6th Gear
Default Changing Handlebar switch Housings
I'm thinking of changing my stock black switch housings on a 2006 electra glide standard with cruise controls and radio controls. I have the easy bolt on covers by Kuryakyn that don"t require taking apart the switch housings. I was wondering how hard it is to actually take them apart and replace them with the chrome ones, On a scale of 1-10 1 being say changing the battery 10 being engine work. If I decide to change the housings is it worth doing the handlebar grips as well does the increase the difficulty level by alot. Thanks for any insight
Old Feb 5, 2010 | 05:56 AM
SBW Cycles's Avatar
SBW Cycles
In my opinpion, it is about 3-4. Nothing hard to take a part and put back together. The hardest thing is not pinching wires. I have done bunch a sets. With the radio controls, it just takes a little longer. With a 6 pack and some patience it should take about 1-2 hours. Normally when I am switching out the controls I also do the grips since you have to remove the throttle anyways.
Old Feb 10, 2010 | 06:29 PM
madmatt500's Avatar
madmatt500
6th Gear
Thanks for the Info SBW
Old Feb 10, 2010 | 06:33 PM
KingCripps's Avatar
KingCripps
I don't do engine work, but I have changed switch housings a couple of times. I agree, its about a 3 or 4. You may want to do switch caps at the same time so you don't have to take them apart again.
Old Feb 10, 2010 | 06:40 PM
tombeving's Avatar
tombeving
Also make sure you put a spacer in between the brake lever and the housing or you'll break the brake light switch.
jerryw618
Apr 11, 2015 12:16 PM
RodeoHard
Electrical/Lighting/Alarm
Mar 5, 2014 09:25 PM
Finmad
Custom Models
Jan 4, 2014 06:28 PM
zworld
Dec 27, 2011 08:34 PM
TJ461vs
Apr 7, 2006 11:41 PM
