Is there a safe engine cleaner?
Old Feb 5, 2010 | 09:05 AM
bfrank's Avatar
bfrank
Originally Posted by TheDon81
I swear S100 is just another Simple Green solution.
At twice the price! Simple green is cheap and easy and it works.
Old Feb 5, 2010 | 09:10 AM
gmc's Avatar
gmc
+1 Simple Green, I don't cut it for the engine, etc., just spray it on and let it set for 5 min. then rinse well. I've started using the S100 Engine Brightener when the black is faded.
Old Feb 5, 2010 | 09:14 AM
WildThang's Avatar
WildThang
I cringe every time I hear Simple Green mentioned...given its horrible track record with aircraft (very corrosive and cause hydrogen embrittlement in high strength steels...etc)
Old Feb 5, 2010 | 09:18 AM
Leftcoaster's Avatar
Leftcoaster
Beware of products like Super Clean. That stuff will clean ovens and is very caustic. Also stay away from Brake Clean - it'll remove any and all wax plus it pretty tough on painted surfaces. Don't ask me how I know. Formula 409 will degrease the bottom of your bike and is fairly safe but I always rinse it off with a low pressure sprayer promptly to be sure.
Old Feb 5, 2010 | 09:44 AM
krom nutz's Avatar
krom nutz
I can tell you not to use the degreaser at the car wash on a hot motor. Ive got spots all over the black engine paint. Rookie mistake , wish I'd asked fist. Hope theres a way to restore it ??
Old Feb 5, 2010 | 09:45 AM
jimsreddyna's Avatar
jimsreddyna
I cut and pasted this from Simple Greens web site. If they feel the need to caution you on the use of their product on aluminum, that is good enough reason for me to not use it.
Here is the link to the page that I coppied it from.
http://www.simplegreen.com/solutions..._backup=danger
Here is the quote from their page.
Aluminum - Is it safe to use Simple GreenŽ on aluminum?
When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple GreenŽ Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple GreenŽ Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple GreenŽ product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Old Feb 5, 2010 | 10:32 AM
bwana1's Avatar
bwana1
Once again, BIKE BRITE! Made for cleaning motorcycles, not caustic, and will not damage painted or chrome surfaces.
Bwana
Old Feb 5, 2010 | 10:43 AM
Navy Mustang's Avatar
Navy Mustang
DO NOT USE SIMPLE GREEN unless it's on your enemy's bike. It's terrible.
I use Greased Lightening from Lowes, works great. Followed up with a good drenching of Armor All. That stuff keeps the engine as black as night and also smells pretty good when you're riding down the road
Old Feb 5, 2010 | 10:47 AM
BigAlsRK's Avatar
BigAlsRK
I was told to spray on and then rinse off....would never leave any cleaner on for 10 or more minutes.....
Old Feb 5, 2010 | 11:03 AM
Damascus's Avatar
Damascus
I've been using WD-40 for years and it has been completely safe on metal and plastic. Cleans off grease, road grime, etc, and it's cheap! Spray on/wipe off. You will be amazed. Pretty certain it will take scuff marks off chrome but I have not tried that myself. Just mop up good before you take off so your tires don't slip on it and down you go.
Happy Friday All!
Murph
