Is there a safe engine cleaner?
Old Feb 5, 2010 | 08:14 AM
paulhog's Avatar
paulhog
Default Is there a safe engine cleaner?
I'd like to degrease the bottom of the engine and clean some of the crud off the electrical wires. Is there a safe cleaner I can spray on the entire engine area? Thanks.
Old Feb 5, 2010 | 08:30 AM
bwana1's Avatar
bwana1
BIKE BRITE works great. Will degrease engine, but is not caustsssssic, so it does not damage paint. Use it on a cold bike and hose it completely clean two minutes later.
Bwana
Old Feb 5, 2010 | 08:31 AM
BigAlsRK's Avatar
BigAlsRK
I have heard some people swear by Simple Green....I'm gonna give it a try as soon as this freakin' weather cooperates.
Old Feb 5, 2010 | 08:32 AM
paguy's Avatar
paguy
I've been useing 50% cut simple green. I'm useing the regular stuff now, but a year or two ago I was able to buy a heavy duty at A&A auto. Same price.
Not on a hot engine. Cool engine, out of the sun, leave on 1-2 minutes wash off. If your grimed up it may take a couple of cleanings.
Old Feb 5, 2010 | 08:33 AM
WildThang's Avatar
WildThang
Brake Cleaner...cheap...effective...safe...
Old Feb 5, 2010 | 08:36 AM
bfrank's Avatar
bfrank
That's what I use. I buy that stuff by the gallon case and use it for a lot of cleaning projects.
bfrank's Avatar
bfrank
Can't you damage your paint using that stuff?
Old Feb 5, 2010 | 08:54 AM
frenchbiker's Avatar
frenchbiker
+1. That's what I use on my engine, wheels, rotors, calipers and chrome. Spray, let soak for a couple of minutes and rinse. It does an excellent job.
Once the engine is clean, I spray Pig Snot or Pig Spit works great on black parts.
Old Feb 5, 2010 | 09:00 AM
tas_todd's Avatar
tas_todd
Simple Green sounds like something I need to try. I've been using Bike Brite then S100 engine brightner after.
Old Feb 5, 2010 | 09:03 AM
TheDon81's Avatar
TheDon81
+1 on Simple Green cut, 50/50 and change depending on how bad the grease is, I also use Purple Power with good results.
I swear S100 is just another Simple Green solution.
