cop bike chameleon
Obviously to do this you'll need to relocate the air reservoir for the seat. I had a cop seat on my Street Glide and ran the reservoir into the left saddlebag. Just required a very small hole drilled in the inboard side of the saddlebag for the air line, then velcroed the reservoir to the interior. Worked like a champ.
Keep in mind that you can't use the regular H-D Tour-Paks if you have the stock Cop saddlebags. The lids don't clear the Tour-Pak. There are some aftermarket Tour-Paks made specifically for cop bikes; I think E-Glide Goodies sells them.
I did this same process on mine except the seat air tank was already removed. I have both positions, a solo seat and two up seat and ended up keeping it in the tourpak 2-up position 95% of the time.
I hope you are sufficiently confused, it took me a while to get the bike set up.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
As you can see, different racks are offered for '09 bikes and '08 and older models.
Second, I haven't spent hardly any time looking at '09 and newer police models so a picture of what you have on the back of the bike would be helpful. If it's like the '08 and older bikes, it will have a radio rack on the back with the air tank bolted to it and mounted on the bottom of the black rack. The chrome bracket that supports that stuff is the same as the bracket used to permantently mount tour paks on Classics and Ultras. That will have to be removed to use HD's detachable solo or two-up tour pak racks. Once it's removed, you can use the same mounting hardware and two-up detachable rack that are used on other Touring models.
The air ride seat may present issues if you want to use a solo detachable tour pak rack. If you use a civilian seat and don't have the permanent tour pak bracket on the bike, you can (probably) use the same mounting hardware and solo rack used on civilian bikes.
Suggestions: (1) Spend some time reviewing the HD parts books for 2009 civilian models and the supplement for the police models so you can see what, if anything, is different about your police model regarding the installation of detachable hardware and tour pak racks/backrests/etc., (2) pay close attention to replies from owners of '09 and '10 police models as it relates to installing detachable accessories; and, (3) pay close attention to posts regarding relocating the air tank regardless of model year since that system is (probably) the same regardless of the model year of the bike.
Good luck with your research.
I really do appreciate members, such as yourselves, who take the time to inform those of us looking for legitimate help. that is how i envision a "forum" to be, not some of the "drivel" i have seen on these pages in the last two weeks....trying to follow some of those threads, makes me reach for the duct tape, so that i can wrap my head before it explodes!
hopefully, i can return the favor sometime in the future.
adios,
will
Note: Scootworks makes two different size boxes: CruzPac & SuperTrunk III. Squadfitters makes a standard box without lights...neither as pricey as the HD
