2nd accessory toggle switch?
Old Feb 8, 2010 | 11:37 AM
07FLHT's Avatar
07FLHT
Vibe Rider! LOL!!
Old Feb 8, 2010 | 12:20 PM
BMF's Avatar
BMF
Asked the dealer that same question Saturday about a 2009 Road King. He said it is most likely under the seat but could also be behind the head light assembly. Said it depends on which line it came off, sounded kinda funny to mee too. I haven't gone looking for mine yet but want to add a sound system before spring and think I might wire it to that switch.
Old Feb 8, 2010 | 12:25 PM
rkoivisto's Avatar
rkoivisto
Default Acc connector
The accessory connector will be under the seat on a streetglide. Right in front of the battery.
I use mine to switch maps on a PC V. Just put a 12 Volt relay on it. I set it so if I need electric gear, I unplug the PCV and plug in the gear. If it's cold enough to need the electric gear, it's cold enough to run on the leaner map.
Old Feb 8, 2010 | 05:16 PM
woodhog17's Avatar
woodhog17
Mine's wired to a plug for heated gear or any other 12V acc. that you can plug into it.
GroovusMagnus
2014-2024 Touring Models
May 16, 2015 08:03 AM
davidwruth
May 11, 2013 04:19 PM
Bagger07
Mar 15, 2013 07:21 PM
Hrlyrider
Jun 27, 2010 02:08 PM
ONLYTNT@YAHOO.COM
Sep 19, 2009 12:49 PM
