misfire in high revs?
Old Feb 18, 2010 | 07:35 AM
VETERAN75's Avatar
VETERAN75
Default misfire in high revs?
Ok, I recently installed 204 cams, SEAC, RH TD, SERT, Hogtunes amp and speakers, cruise control, and SE compensator sprocket. Now it seems I am missing spark or something in the mid to higher revs. Everything checks out ok, all the grounds are good, compression check is good, tried new plugs, wires, and changed the gas. The bike has pretty much sat for 12 months while I was deployed. Any gurus or techs care to take a stab at suggestions. Thanks in advance.
Old Feb 18, 2010 | 08:54 AM
VETERAN75's Avatar
VETERAN75
Just found out the bike has no problems at all. The problem lied in the SERT.
Old Feb 18, 2010 | 08:56 AM
Gliden's Avatar
Gliden
And what was that problem??
Old Feb 18, 2010 | 09:25 AM
mainshaft's Avatar
mainshaft
That's what we like quick fixes. +1 one what was the cause...
Ragz Ultra
Audio Systems
32
Aug 22, 2016 12:39 PM
markbuc
Feb 19, 2008 07:12 AM
UltraKla$$ic
13
Jun 1, 2007 10:59 PM
Islander
Nov 23, 2006 02:29 PM
TedMan
Sep 6, 2006 01:26 PM
