Need Street Glide Tie Down Help!
Old Feb 21, 2010 | 10:04 PM
Wonderbob's Avatar
Wonderbob
Default Need Street Glide Tie Down Help!
Don't even start! Yes I'm trailering my brand new Street Glide to Daytona. Trust me its not my choice, but it's a long story.
So, whats the best way to tie down? With my Street Bob it was a no brainer, just hooked the tie downs under the tripple trees on either side for the front and the back end was held down at the swing arm.
Help I'm leaving on Thursday.
Thanks!
Old Feb 21, 2010 | 10:07 PM
soos's Avatar
soos
Try this:
Attached Thumbnails Need Street Glide Tie Down Help!-left-front-1.jpg   Need Street Glide Tie Down Help!-right-front-2.jpg   Need Street Glide Tie Down Help!-right-front-3.jpg   Need Street Glide Tie Down Help!-right-passenger-4.jpg   Need Street Glide Tie Down Help!-right-passenger-5.jpg
Old Feb 21, 2010 | 10:09 PM
captjon37's Avatar
captjon37
I use soft ties around the forks just above where the fender bolts on. 2 more on passenger boards and 2 on the rear tire but the key to the whole thing is my condor wheel chock as it does much of the work. This is on my UC but should be similar.
Well, there you go, Soos is the man with the plan and he is where i got my info from and i use his method and it works perfectly.
Old Feb 21, 2010 | 10:16 PM
Wonderbob's Avatar
Wonderbob
I gotta say thats what I love about this place. Post and answers appear. Awesome.
What a great site for answers and support. Now to try and pull off the same thing on a Kendon trailer.
Open Road's Avatar
Open Road
I use a Kendon dual rail trailer.
I'd never tie to the front end......just don't thing it's a good idea to put any kind of torque on the front end, especially in an abnormal direction.
I use a couple of soft ties around the front down tubes of the frame to the front of the trailer.
On the back I put a tie around the wheel & tire at the deck level and tie straight out to either side of the trailer.
I've only towed 240 miles round trip, to the shop that I use. Sometimes it's just one Street Glide and sometimes it's both. Never been a problem tying it down this way.
Old Feb 21, 2010 | 10:21 PM
2nd Mike's Avatar
2nd Mike
A set of tie downs like these opens up a lot of "no damage" options
http://www.amazon.com/Keeper-05723-H...6811970&sr=8-1
I know the Harley shop also has them.
Old Feb 21, 2010 | 10:23 PM
Wonderbob's Avatar
Wonderbob
I'm running about 500 miles from NC to Daytona. I've got a single tridon, so it sounds like it'll be fine.
Old Feb 21, 2010 | 10:45 PM
Lonewolf176's Avatar
Lonewolf176
Have to agree that those straps are the ticket.
Old Feb 21, 2010 | 10:47 PM
Inspector 12's Avatar
Inspector 12
Just towed my bike to a shop about 200 miles from home. Used a set of tiedowns similar to those in the link, got them at Costco for $18 dollars. I tied from the frame down tube where the front crashbar attaches forward pulling the bike down in such a way that it compressed the front forks some but still had movement. I also put the jiffy stand up so that it was not resting on the floor. I also tied through the rear wheel pulling it backward with light pressure. Got there without any problems.
Related to this, highly recommend checking the tiedowns when you stop. Did have one strap slip a little in the ratchet but not enough to cause a problem.
Old Feb 22, 2010 | 04:58 AM
stukes_md's Avatar
stukes_md
I have a Condor wheel chock on the trailer and only tie down the rear of the bike from the passenger floorboards with 2" straps. The straps are oriented forward to keep the front wheel in the chock. I've towed from Charlotte, NC to Orlando and back and two other round trips from Charlotte to Ocean City, MD. Bike did not move.
