Power Commander/Thundermax
Old Feb 24, 2010 | 07:50 PM
dan boudreau's Avatar
dan boudreau
Default Power Commander/Thundermax
I have decided to put a fuel management system in my 05 which has a 103, have for the most part made my decision as to what brand. Just looking to see what is the prefered choice and any opinions. thanks for all the help.
Old Feb 24, 2010 | 11:38 PM
gregm's Avatar
gregm
My indy recommended a Power Commander III USB when I did the cams & gear drive mod. The mechanic who did the dyno tuning told me that a big advantage with the USB is that the computer tunes it in less time and with less wear & tear than non-USB models. He said that he's seen clutch and starter problems caused by the repeated run-ups and starting/stopping needed to dial in non-USB systems. Another advantage of the USB system is that each cylinder can be individually adjusted. I assume that holds true for any computer tunable fuel system.
Gregm
Old Feb 24, 2010 | 11:57 PM
RThomas4223's Avatar
RThomas4223
Dan:
I'll tell you next week. I have an 02 EGC with 95" engine, 203 cams, PCIII, Reinhart true duals & SE mufflers. The stock mufflers were 'way too restrictive, & I went with a set of barely legal SE slip ons. Then, over time, they just got too loud. I then installed a set of 2007 SE slip-ons. The tuner 'ran into a wall' with those mufflers as the "sniffer" has to fit past the mufflers & into the tail pipe. The late-model SEs have a baffle about 1/2 way up so the tuner didn't want to waste my $$ by doing an inaccurate tune.
That caused me to go to Fuelmoto & get the ThunderMax with Autotune. It's being installed even as I write this, but the weather is so bad I'm not going riding until the rains clear up.
So, I'll let you know next week. I'm hoping to get better gas mileage as I'm not a hot-rodder, but still only get 34-36 MPG.
After I installed my oil temperature gauge, I had a sneaking suspicion that maybe my engine wasn't warming up enough in the winter weather to get the Delphi off whatever the EFI equivalent of the "choke" is.
I found Jamie & FuelMoto to be excellent to deal with.
Old Feb 25, 2010 | 12:14 AM
genedjr's Avatar
genedjr
Default many options
I have a TMAX w/AT - because I will make many changes over time. (search my posts for more details)
So what are your plans? Both are great devices and will serve you well. But - the PowerCommander III requires a real tune to be effective. If you plan to change alot, that is alot of tuning - read money.
But if this is IT - PC3 is great, add $500 for a good tune and your in 7th heaven.
...gene
Old Feb 25, 2010 | 12:17 AM
SBJJC's Avatar
SBJJC
I have the Power Commander III, with V/H true duals Rush Slip-ons and a V/H air intake. The bike runs great on the power commander, I really like it. I had a lot of back popping and the bike was running rich. I added the Power Commander and bam, everything was fixed and now runs like a sports bike.
Old Feb 25, 2010 | 08:42 AM
Heathen's Avatar
Heathen
I run the PC111 , find it very easy to tune ,have also used SERT and Direct-link . They all have there good points just more comfotable with Power Commander.
Old Feb 25, 2010 | 08:48 AM
mongomark's Avatar
mongomark
Fuel Moto can hook you up with their "retro" Power Commander V. I'd go with the autotune modules but you'll need to weld the o2 sensor bungs in the exhaust. Jamie at Fuel Moto can hook you up with a map for your combo and the Autotune will dial it in. It's a bit pricey ($300 for the PCV, $300 for the autotune modules), but when you compare the initial price vs. dyno tuning and the fact the system will autotune adjust itself for any additional mods you make, you can't beat it.
Old Feb 25, 2010 | 09:16 AM
WI Bob's Avatar
WI Bob
The PCV w/Autotune is not expensive comparted to the T-Max.
Old Feb 25, 2010 | 08:26 PM
dan boudreau
Thanks to all for the reply's leaning towards the PCIII for my bike as well as my wifes' 06 Street Glide.
Old Feb 25, 2010 | 11:58 PM
mongomark's Avatar
mongomark
For the same money of the PCiii, you can get the PCV retro from Fuel Moto, have lifetime access to Jamie's maps and later on can add the autotune if you so choose. I had the PCiii, went to the PCV, and using it is very similar. Just food for thought.
