Plug wires and plugs changed - change to engine performance?
Old Mar 4, 2010 | 03:06 PM
davessworks's Avatar
davessworks
Default Plug wires and plugs changed - change to engine performance?
While I was overhauling my Softail I changed to SE plugs and plug wires. My bike's EFI (2001) and running high compression pistons. The plugs I took out were the standard 6R12s that a shop had put in (I'll never go back to that shop - but that's another story). Regardless the 6R12s had been doing their job as had the stock wires.
When I took the bike out it ran fine but I got the sense that the timing was a little different and at higher rpm the bike seemed to vibrate more than I remembered (now I admit I'd just been riding the Ultra Ltd for several weeks without riding the Softail - so it could just be the difference between the two) - I'm concerned that I may have inadvertantly changed the characteristics of the bike enough to throw off some tuning parameter and that I might be doing harm to the bike to run it this way over the long term. Thoughts?
Old Mar 4, 2010 | 03:41 PM
hog-doc's Avatar
hog-doc
SE wires are just like doing a set of Taylor or MSD wires on a small block, better insulation to you dont get spark wander and lower resistance , so no they wont change the way the bike runs.
As far as plugs go, go back to the 6R12's NEVER seen them cause a problem. Have seen EVERY other brand of plug out there cause problems that were cured by going BACK to 6R12's
Old Mar 4, 2010 | 03:52 PM
davessworks
Thanks Hog-Doc. The plugs I put in are 32186-10 I think but since the 6R12s were working fine I'll switch back! Good advice as usual!!
(I'm running about 10.5:1 CR)
hd4evr2008
Apr 2, 2016 10:53 PM
Kahuna
Jun 5, 2015 07:30 PM
ToadsUltra07
Apr 15, 2015 09:45 AM
BoredOutMyMind
Mar 8, 2014 05:51 PM
oldairboater
Jun 24, 2011 09:43 PM
