Moving backrest bracket further back...?
Old Mar 13, 2010 | 09:46 AM
FEV's Avatar
FEV
Default NEED HELP! Moving backrest bracket farther back...?
Hello all - after trying multiple seats, I am happily riding my 01' Ultra using a Pro Pad Cyclopedic seat. Moved my 6'2" body into a great position. PROBLEM: the opening for the backrest is now also more rearward - I have the bracket all the way back (see pix) and it needs to go back even more for comfortable riding and so as to not stretch the seat opening... So, any great ideas on how to extend this bracket? Reverse (might change the angle) and weld on a new tab for the front support? Is there an extended bracket with more holes/adjustment available? Thanks in advance for the help!
Old Mar 19, 2010 | 05:47 PM
FEV's Avatar
FEV
Default Help!!
Any help out there on moving this bracket back???
Thanks!
Old Mar 19, 2010 | 06:15 PM
stro1965's Avatar
stro1965
You could always just bend the bars a little.
Old Mar 20, 2010 | 09:10 AM
FEV's Avatar
FEV
Thanks for the reply - I am trying to pick up an inch or two.
Frank
Old Mar 20, 2010 | 10:11 AM
imrotton2's Avatar
imrotton2
get some metal about the same thickness. drill holes in it to fasten to 2 exhisting holes the drill extra holes for further adjusting
Old Mar 20, 2010 | 10:22 AM
TheShrink's Avatar
TheShrink
Looks like you need to weld some longer tabs on, then worry about getting the backrest threw the hole on the seat.
Old Mar 20, 2010 | 11:02 AM
FEV's Avatar
FEV
Thanks - will show it to a welder friend.
Anyone know if an "extended" bracket exists??
Old Mar 20, 2010 | 04:06 PM
davep's Avatar
davep
Moving the bracket further back will cause a problem for you when you try and install the seat to the bracket. Need to cut the seat in order to install the legs of the back rest to the bracket you moved back. Good luck
Old Mar 20, 2010 | 04:31 PM
shortride's Avatar
shortride
Plus what davep said, I suppose you could drill a couple new holes in the fender and relocate the threaded mounting bolts.
Old Mar 20, 2010 | 07:20 PM
FEV's Avatar
FEV
Thanks for the suggestions & help guys - one of the great things this forum is known for!
As to the bracket interfering with the seat, the ProPad seat's opening is significantly further back, so it should be no issue when the bracket slides back.
Again - thanks to all!
doug62
Nov 22, 2016 07:25 PM
chief1600
Apr 10, 2013 09:33 AM
Candubrain
Nov 8, 2010 08:07 PM
Biff_H
Jan 24, 2009 12:27 PM
bowhunter7532
Aug 8, 2008 07:12 PM
