grinding feeling when leaning on turns
Old Mar 19, 2010 | 04:19 PM
Xguy's Avatar
Xguy
Default grinding feeling when leaning on turns
I dunno if anyone has experienced this , but when I lean the bike to turn , I get the grinding feeling at the handle bars, could it be motor mount? or bearing or is this just normal?
thanks
Old Mar 19, 2010 | 04:25 PM
fireaxxe's Avatar
fireaxxe
My 09 felt like this when I had the 407 dunlop tire that was cupped on the front. check the forum for the recall information. If you do not have this tire it could be front wheel bearings.
Old Mar 19, 2010 | 04:34 PM
ddm502001's Avatar
ddm502001
My '03 started this awhile back, I have the cursed 402 Dunlops, seem they have this issue. I have checked and rechecked everything else. I am awaiting the wear out on my rear tire and may change both to E3's.
'03 RK Anniv. Ed., Tourpak, Monster Ovals and Fuelpak, DCC fairing, W1 RKII bars, K&N on a S/E base, Mustang Seats, Thunderstar wheels
Old Mar 19, 2010 | 04:44 PM
TMART's Avatar
TMART
Yep,it probably is the tires,they wear smooth in the center of the tread and the outsides still have alot of tead on them and are only in contact with the road during leaning turns,Mine stopped when I replaced the tires.
Old Mar 19, 2010 | 08:44 PM
Xguy's Avatar
Xguy
well that's conforting I was worried something is wrong, I can live with it if I know for sure it's just a tire grinding.
Old Mar 19, 2010 | 09:16 PM
CroK's Avatar
CroK
Rub your hand over the tire. If it's cupped, you'll feel a difference in the tread. If it isn't cupped, I'd lift it off the wheels and check for play in the bearings. Also, rotate the tires by hand and see if there is any unusual noise (grinding or rough feel).
Old Mar 19, 2010 | 09:21 PM
Xguy's Avatar
Xguy
can someone explain to a noob what the term "cupped" means
Thanks
Old Mar 19, 2010 | 09:54 PM
Damascus's Avatar
Damascus
The grinding I get when riding hard in curves is the floor board supports on the pavement. If yours are worn down, that could be what's going on. (???)
Old Mar 19, 2010 | 10:00 PM
S1 4 Life's Avatar
S1 4 Life
I was going to say floorboard, I grind mine all the time.
Old Mar 19, 2010 | 10:14 PM
Xguy's Avatar
Xguy
Nah I'm not talking about hard cornering, this feeling I get as soon as I lean the bike even a tiny bit, and it's constant as long as the bike is leaned, I can distinguish that from the floorboard scraping which only happened to me only a few times.
I am beginning to believe it is the tires, gonna go down and check them now and might as well get the sizes and start looking at my options, they do have already 7500 miles on them.
