Chrome front end/ inside fairing
Old Mar 20, 2010 | 07:28 PM
fumesflhx's Avatar
fumesflhx
6th Gear
Default Chrome front end/ inside fairing
i was thinking of tackling: Changing my inside fairing, chrome front forks, and front end lowering kit. My friend and i are pretty familiar with working on the bikes, but not to that extent. Is this a massive project or one that is better left to the proffessionals?
Old Jul 27, 2010 | 07:53 PM
Dre424's Avatar
Dre424
Done yet? Post pic please
Old Jul 27, 2010 | 07:58 PM
shortride's Avatar
shortride
I was wondering that also.
Old Jul 27, 2010 | 08:10 PM
Da Butcher's Avatar
Da Butcher
The inner fairing is an absolute joke, in a good way! The dealers want hundreds of dollars to do it and some try the scare tactics to make sure you don't try. Use the 'search' tool here to see much more on the swap. I wondered just how hard could this possibly be, it's only a damn fairing. This being the best Forum on the planet proved I was right. It was easy. Using a bit of common sense such as covering your paint, labeling the wiring you're not familiar with, and so on. You'll be fine. Buy the HD Service manual if you don't already have one. And since you'll have the fairing off anyway? Do the forks while you're in there.
Use the search feature here.
Buy the manual.
Take you time.
Use common sense.
Good luck!
Old Jul 27, 2010 | 11:40 PM
Bill03E's Avatar
Bill03E
This Job isn't what I would call hard, but it will take time....the easiest thing I have found to do is take a bunch of pics after you get the outer off this way you know the correct routing of the cables, and wiring ...pretty easy after that, the forks are not that bad , my left side was seized in the upper tree so I used a rubber strap wrench to turn it, and then it came right out.
JoeN
May 15, 2010 06:12 AM
omgtkk
Apr 3, 2009 08:41 PM
Buster747
General Topics/Tech Tips
Jan 2, 2009 01:56 PM
fryeca
Jan 7, 2007 09:11 PM
bluehwytn
Apr 26, 2006 07:20 AM
