Front Brake Rotor squealing
Old Mar 20, 2010 | 08:47 PM
Riding Rookie's Avatar
Riding Rookie
6th Gear
Default Front Brake Rotor squealing
I have a 2000 Electra Glide and about 2 to 3 weeks ago I noticed my front brake rotor was squealing as I am rolling not braking and it has been getting worse. I have checked for loose parts but everything is tight. Any suggestions on what my problem could be?
Old Mar 21, 2010 | 10:18 AM
gli.der's Avatar
gli.der
I'm having the same issue. Mine is definately coming from the brakes, not bearing. It was recommended that I remove the rotors and clean the pistons, they may be hanging up. I have to remove the wheel to get the rotors off (lowered fender). If you have a lift, see if you have alot of resistance when you spin the wheel. I do. I'll probably pull the wheel today, after my ride. I'll let you know what I find.
Old Mar 21, 2010 | 10:52 AM
gli.der's Avatar
gli.der
I meant that it was recommended that I remove Calipers.....not rotors.
Old Mar 21, 2010 | 11:38 AM
Punjabi Rider's Avatar
Punjabi Rider
Some times rotors have build up on em try scrubbing with SOS pads or Comet powder that might help.
Old Mar 21, 2010 | 12:19 PM
xxxflhrci's Avatar
xxxflhrci
Swap to Kevlar pads and the noise will go away.
Old Mar 21, 2010 | 12:33 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
mine have been doing it ever since I polished them. Drives me crazy.
Old Mar 21, 2010 | 12:37 PM
hog-doc's Avatar
hog-doc
Sometimes you can get it to stop with some hard stops. Get the rotors warmed up and do some 20 mph to almost stopped with heavy lever input. Do it three or 4 times and it will usually quit. Just had to do it to mine the other day!
If you do it on cold rotors you can crack them!
Old Mar 21, 2010 | 02:46 PM
n8dc's Avatar
n8dc
red scotch brite pad ....... Available at auto paint stores
Stomper-63
Jul 6, 2020 03:11 PM
flyboyslc
Sep 15, 2016 06:14 PM
TwoBlue02
Sep 12, 2016 06:20 PM
gschwerman
Mar 26, 2013 10:59 AM
Figstr
Jan 5, 2010 11:08 AM
