Rear shocks air pressure
Old Mar 20, 2010 | 10:44 PM
makstv5's Avatar
makstv5
Default Rear shocks air pressure
What do the 2010s have in them new from the dealerships? What are some of you running for pressure with these 12'' shocks?
Old Mar 21, 2010 | 08:10 AM
Bogart's Avatar
Bogart
Mine had 13psi upped it to 23psi for 2up. Total weight for both is 285lbs
Old Mar 21, 2010 | 08:52 AM
hardwork2's Avatar
hardwork2
My Limited has 40lbs 2 up total weight 400lbs
Old Mar 21, 2010 | 08:55 AM
FLS2FLH's Avatar
FLS2FLH
I'm running mine around 30lbs for a 190lb rider + luggage. Seems to be a good happy medium.
Old Mar 21, 2010 | 08:57 AM
elauee1's Avatar
elauee1
I up mine from 10 to 20 much better ride I am 190#
Old Mar 21, 2010 | 09:02 AM
bmaier's Avatar
bmaier
only the 09 and 10 with the new frame/swingarm call for 50psi max. I run 40-45 with two up and luggage. Seems like with the full 50 when you hit a sharp bump at speed you get a big rebound bounce so I like to run a little less to reduce that bounce.
Old Mar 21, 2010 | 09:06 AM
bob2002's Avatar
bob2002
Riding two up at 350 I'm at 30 PSI,sometimes it feels too soft sometimes too hard with the condition of the roads in the N.E. I think about 5-6 inches of travel would help.
Old Mar 21, 2010 | 10:13 AM
SC_Compact's Avatar
SC_Compact
12 lbs and I weigh about 190 lbs. I tried 18 lbs last year on a long trip and it was downright painful on some of the frost heaves. I could feel my neck compressing at times.
I am considering a set of Progressive 412's for about $210 on Ebay.
Old Mar 21, 2010 | 10:16 AM
brockstwrt's Avatar
brockstwrt
30 one up 45 two up
Old Mar 21, 2010 | 11:21 AM
canuck pride's Avatar
canuck pride
Its a 2009 and we ride 2 up at about 360 total, and I keep it at 40-45 psi and drop down to 35 psi when I'm alone at 200.
