How common is this???
Old Mar 21, 2010 | 01:50 PM
gli.der's Avatar
gli.der
Default How common is this???
I keep getting a drop of oil on the most rear of the two nuts that secure the axle bolt on the bottom of my fork (throttle side). The manual shows a 6mm screw/copper washer that screws up from the bottom in the center of the lower fork under the axle bolt. Before I remove the wheel, i was just wondering if this screw or copper washer might be causing the leak and if this is common. I wrapped a piece of blue masking tape around the fork below the drain plug to see if the leak was coming from above. Its leaking below the tape somewhere.
jeffjackman
General Topics/Tech Tips
May 3, 2019 09:16 AM
bmcgc
Nov 21, 2010 08:38 AM
joechief
Jun 14, 2009 09:46 PM
pennetta
Feb 10, 2008 07:21 PM
03 Softail
Apr 24, 2006 12:37 PM
