Screaming Eagle breather kit
Old Aug 2, 2006 | 07:27 PM
capt42a's Avatar
capt42a
Default Screaming Eagle breather kit
Hello,
I bought a Screaming Eagle breather kit for my 2006 FLHT/I today and I'm looking for any tips on the install.
Thanks,
capt42a
Old Aug 2, 2006 | 07:49 PM
spartns's Avatar
spartns
Default RE: Screaming Eagle breather kit
It's pretty easy. Unbolt the old, bolt on the new. One thing I would sugest is getting a filter for the breathers on the heads. If you have them (the rubber hoses) plugged into the back of the unit sometimes you can get oil blowby and it"ll leak all over the right side of your bike. Good luck
Old Aug 2, 2006 | 08:09 PM
bountyhunter's Avatar
bountyhunter
When the SE filter gets dirty[X(], toss it & replace with a K&N, HD-0800!
Old Aug 3, 2006 | 12:27 AM
capt42a's Avatar
capt42a
Thanks for the reply's spartns, and bountyhunter. spartns, what filter to catch the oil are you talking about ?
Thanks,
capt42a
Old Aug 3, 2006 | 07:06 AM
Grover's Avatar
Grover
Administrator Emeritus
Be sure to use LocTite and a torquewrench on the banjo bolts going into the side of the heads. If they vibrate loose, it is a fine black mist of oil all down the side on the bike.
Don't ask me how I know.
Old Aug 3, 2006 | 07:50 AM
claydbal's Avatar
claydbal
ORIGINAL: Grover
blue loctite!!!!!
Old Aug 3, 2006 | 09:09 AM
spartns's Avatar
spartns
Your dealer has, or should have, a filter that you run the hoses into. About $18.00. Or, you can check JP Cycles or Denis Kirk. They both have kits for the breathers.
Old Aug 4, 2006 | 07:19 PM
capt42a's Avatar
capt42a
Thanks for all the reply's.
capt42a
Ndoggct
Apr 5, 2019 07:59 PM
Boston62
Carburetor Related
Sep 27, 2012 06:59 AM
Pondskipper
Mar 20, 2012 02:48 PM
rlj2
May 18, 2008 11:40 AM
hawnstar
Apr 28, 2005 01:18 PM
