Would a 2000 RK clutch adjustment
Old Mar 21, 2010 | 07:38 PM
DPete's Avatar
DPete
Default Would a 2000 RK clutch adjustment
be the same as my 09' SG, got a buddy to help out but don't want to steer him wrong. I asume it's the same
Old Mar 22, 2010 | 09:19 AM
DPete's Avatar
DPete
Dawg, you out there?
Old Mar 22, 2010 | 09:20 AM
jdreed520's Avatar
jdreed520
2000 rk should be seat the adjuster and out 1/2 to 1 turn. then take out the slack in the cable...I normally do mine about 1/2.
Old Mar 22, 2010 | 09:22 AM
dawg's Avatar
dawg
Yes it would be the same. Collapse the cable, open the derby, loosen nut, bottom out adjuster a few times so you know where it is that you are feeling the tension of it just bottoming out, back it off 1/2 turn (or whatever your pleasure of happiness, mine's 1/2), tighten nut, work clutch lever a few times to make sure ball and ramp is seated, adjust cable at perch (I use a nickel's width for the gap)
Old Mar 22, 2010 | 09:24 AM
DPete's Avatar
DPete
Thank you, I set mine @ 1/2 out also
Old Mar 22, 2010 | 09:25 AM
jdreed520's Avatar
jdreed520
Thanks for adding to this post DAWG i could not remember what the book said but i also do mine 1/2...........
Thanks DAWG to the rescue.
blcarizona
May 4, 2017 07:16 PM
89FLHTC
EVO
11
May 3, 2016 07:34 PM
dynhd1
Aug 30, 2010 08:44 AM
tut60
Jun 7, 2009 04:14 PM
Pugz2727
Sep 7, 2007 10:00 AM
