Street Glide RIDER Backrest
Old Mar 24, 2010 | 03:26 PM
  #31
Gliden's Avatar
Gliden
Default backrest
Originally Posted by michaelm
For what it's worth...have you considered changing your handlebars? A couple of inches more pullback may help your back more than any backrest. Look at HD's own pullback bars or Wild 1's WO 575s. The HD bars are stock width, the Wild 1s are a bit (3") wider.
My buddy said that too...he swears by his pullbacks.
Thats alot of work for me to swap those out...I have heat demons inside the bars n stuff....I'll keep it in mind though....thanks for the suggestion....
Old Mar 24, 2010 | 03:49 PM
  #32
Route66rider's Avatar
Route66rider
I recently bought the so called "fixed" backrest for my '05 Ultra. The thing is that it has multiple hole positions on the base portion that allow you to select the forward/backward location. Once that is selected, the actual back has a set screw that allows the angle to be changed.
Old Mar 26, 2010 | 11:25 AM
  #33
Gliden's Avatar
Gliden
Default backrest
And your pad can sit right on top of your seat right?
I have this 6 inch bar visable sticking up and then the pad....
I'd like to have the pad low down by the seat but I guess the "adjustable" $300.00 version doesnt allow that!!
Old Mar 26, 2010 | 12:33 PM
  #34
flyingace's Avatar
flyingace
None of them will fit down tight to the seat with the stock SG seat. The backrests have to work with seats that are anywhere from 2 inches thick to 5 inches thick. So, you have a thin seat, its gonna stick up higher above the seat. Look at my pics with the same backrest with the SG seat, vs the Sundowner seat.
Streetglide seat with compact style:
Sundowner seat with compact style:
Mustang 1 pc seat with compact style:
Mustang 1 pc seat with compact style (note passenger legroom):
Old Mar 26, 2010 | 02:31 PM
  #35
Gliden's Avatar
Gliden
Default backrest
Jesus that bike is beautiful!
Yours is a fixed mount which is lower....mine is adjustable and because it's the "adjustable mount" the damn thing sticks up about 6 inches of a steel bar (no cover or anything) THEN the pad goes on top of that. It just doesnt look finnished....
Not crazy about the wrinkly loose leather look of the rear of the SG pad either.
Ya think I would have figured all this out BEFORE I bought it!
I have no one to thank but myself on that one....I should have got the fixed mount...at least I wouldnt have to look at the steal bar.
Old Mar 26, 2010 | 11:21 PM
  #36
Stang951's Avatar
Stang951
Which backrest is that, and is the chrome back piece stock with it or added?
Old Mar 27, 2010 | 03:01 PM
  #37
flyingace's Avatar
flyingace
That particular one came from an 08 CV0 Road King, (got it for $100) but they make others in the same shape/size, just not with that stitch pattern, which is unique to the CVO. The backplate was standard on the CVO, but you can buy it as well from the catalog.
Waterman1
Feb 17, 2017 06:50 AM
sudbury2010glide
Aug 30, 2012 10:13 AM
smurfsdad
Jun 24, 2012 10:26 PM
bobbyg
Jan 8, 2008 04:42 AM
sldavis
Dec 31, 2007 08:43 AM
