Accessory Connector
Old Mar 25, 2010 | 07:31 PM
thehueg's Avatar
thehueg
Default Accessory Connector
If you buy the Harley plug kit to connect an accessory to the accessory plug under the seat (08 Ultra in my case), how do you know which of the four holes to plug the hot and ground wire into if you only have two wires?
Old Mar 25, 2010 | 07:37 PM
dawg's Avatar
dawg
THIS link will help you with wiring it up.
Old Mar 25, 2010 | 08:37 PM
Harleypingman's Avatar
Harleypingman
In addition to what Dawg posted, if it's an HD accessory it will come with the wires installed in the connector already or with instructions on where to insert the wires in the connector.
Old Mar 26, 2010 | 02:36 AM
Watch Guy's Avatar
Watch Guy
Default My 09 RK has two accs plugs
One is for the siren and the other for tour pak or whatever. They are identical and run off the same cable. I've plugged in my siren to both and both work the same. Go figure?
OLD 96
Mar 13, 2018 06:00 PM
jackod
Feb 11, 2013 09:01 AM
Razorback Rob
Mar 3, 2012 09:10 PM
bg3075
Aug 14, 2011 03:52 PM
oricko
Feb 22, 2011 03:45 PM
