Fatcat installed....
Old Mar 26, 2010 | 12:45 PM
'05Train's Avatar
'05Train
I've got the concentric baffle in mine....Quiet it isn't. The standard baffle is LOUD. The performance baffle is ridiculous.
catracho's Avatar
catracho
Thank you for the info.
Old Mar 26, 2010 | 12:51 PM
Gliden's Avatar
Gliden
Default Exhaust Flange nuts
Originally Posted by fripple
The fatcat was installed tonight. These are words that I never thought that I would be typing...hahaha! The install went "ok". I lost one of the nuts that mount the exhaust to the head. I heard it "tink" and then I never saw it again. Thankfully my buddy keeps his bike in the same storage building, so I took one off of his....LOL...what are friends for huh? I believe everything tightened up ok. It seemed the bolts that mount to the head were a little tough to get tightened. It seems like they could be tightened more, but when I fired it up I didn't hear any leakage.
Well I got everything together and tightened up. I fired it up and HOLY SH*T. This thing is loud!!!!!!!!!!!!!! It sounds like a freaking big block. It turns out that my old headpipes had the catalyst in them. I didn't get a chance to ride it yet, but hopefully I will tomorrow. I'll try to get some pics up tomorrow.
I think you might want to torque those nuts to same and proper torque and then retorque them in 200 miles or so....
Couple reasons:
1) You don't want to crush the crap out of the exhaust gaskets
2) You don't want those nuts working there way off at a bad time
Since you have to take the time to take off and install the heat shields which I find to be a minor pain in the ***...you want to be worry free regarding the nuts cause they do, can and will fall off if not torqued correctly.
Old Mar 26, 2010 | 12:53 PM
fripple's Avatar
fripple
I have the standard baffle in them. I'll probably torque those bolts down again in a few hundred miles. It seems to me that the D&D have their flanges mounted a little further out than other pipes that I've seen. I'll try to take a picture to show you what I'm talking about.
Old Mar 26, 2010 | 01:05 PM
fripple's Avatar
fripple
I did make one other mistake...haha. I'm no mechanic by any means. I did get a LITTLE anti seize compound on the O2 sensor. I attached a photo showing where I got it on the sensor at. I got as much of it off as I could. It got on the side of the sensor a little. Think it'll mess anything up?
Old Mar 26, 2010 | 02:28 PM
nick@nite's Avatar
nick@nite
Quiet baffle ...nice rumble when your cruising and ncie deep rumble when twisting...
Old Mar 27, 2010 | 07:18 AM
RED RUM's Avatar
RED RUM
Post
D&D states you need the concentric only for stock motor......no upgrades......any upgrades cams or such change to big bore quiet or loud or bourzila
Old Mar 27, 2010 | 07:29 AM
hubble's Avatar
hubble
I was thinking fatcat for my bike, but now not so sure. I'm putting in 255 cams only and I'm thinking this pipe might be to loud.
Old Mar 27, 2010 | 07:40 AM
'05Train's Avatar
'05Train
That may be what D&D states, but it isn't the way it is. I'm making 116/116 out of the 103 in my Night Train with a quiet baffle. It may be hurting the top end a bit, but not by much.
Old Mar 27, 2010 | 08:05 AM
Mysanity2's Avatar
Mysanity2
Man, that's a great looking Night Train.
