Ohlins vs Ricor Comparison
Old Mar 26, 2010 | 07:25 AM
'05Train's Avatar
'05Train
Originally Posted by rthomp159
There are companies out there who modify Ohlins shocks for use on my bike, however you will find no mention of them on the Ohlins website, and according to Ohlins USA, they do not retain the Ohlins warranty.
Originally Posted by SC_Compact
Does Motorcycle Metal fall into this category?
I have no experience with that company other than from this forum. You will not find the part numbers they list on their site on the Ohlins site, nor will you find Ohlins part numbers on their site. I have spoken to Ohlins USA, and they do not make a shock for the rear of my bike.
Take from that what you will.
Based on my experiences from this forum, and on months of research into suspension options, I chose to spend my money on Ricor's products. With unlimited funds, I think I would have gotten the Traxxion front suspension. That said, I am very pleased with the results of the Ricor Intiminators at 1/6 of the price.
Old Mar 26, 2010 | 07:53 AM
marcparnes's Avatar
marcparnes
Yes, I'm sure. That is measured on my '09. Earlier bikes might be different. The total stroke available is 3.3" between the shock mounting bolts. That is calculated leaving a margin of .250" between the r/s axle end and the muffler and .020" between the swingarm and the frame. I told Howard about this a couple of weeks ago. It came up because one of the guys here on the forum was suggesting to shorten the Ohlins by cutting the height adjuster so I told Howard not to recommend that practice. Of course you have bump stops as part of your shocks so you'll never use the entire stroke anyway. In any case, you wouldn't want to be using the frame as a bump stop!
Marc
Originally Posted by HDV-GLIDE
"The real issue is that Harley, even with their new design frame, only allows for a total of 3” of rear suspension travel."
Are you sure about this statement? If so, I'm wondering why I bought Ohlins Shocks with over 4" of stroke???
Old Mar 26, 2010 | 09:35 AM
Hal@Ricor's Avatar
Hal@Ricor
Originally Posted by marcparnes
In an effort to improve the ride on my ’09 Road Glide I’ve tried Progressive 440’s which just felt like heavy springs to me and Works Performance Steel Trackers which were better but still left something to be desired. Over the years I’ve run Ohlins shocks and Road & Track forks on a number of bikes and currently have Ohlins front and rear on my GS. I decided to order a set of Howard’s #3-3 Ohlins assuming they would be as good as what I’ve had from Ohlins in the past.
Soon after placing my order with Howard I was contacted by Don from Ricor to see if I’d be interested in a set of their Intiminators for my forks as well as a set of Ricor’s newly developed shocks equipped with their inertia valves. I figured I might as well get both the Ohlins and the Ricors and keep whatever turned out to be the best.
Ohlins
Even though Howard said he was going to build me a pair of shocks what I actually received was a set of Ohlins’ standard issue HD909 which Ohlins catalogs for a 1988 Road King Classic. Howard did re-spring the shocks with yellow 154 lb springs. The originally supplied springs that come on HD909’s are black dual rate 114/165 lb springs. When I installed the shocks the bike wouldn’t sag at all. Howard decided that there was too much preload and had me reduce it in an effort to get some sag. I put about 200 miles on the shocks in order to break them in but it was obvious that the springs were way too strong for my 185 lb weight. Howard then sent me the 114/165 lb springs that had originally come on the shocks and I installed those. These were a little better but the 114 lb portion of the spring is two coils and it only takes a bump of 5/8” to bottom them out so the 114 lb rate was pretty useless. What was left was the 165 lb portion which was way too much spring. Besides that, the dampening was insufficient. The sweep valve did not have enough effect to slow down the stroke. The result is that when you hit a bump the shock would blow right through stroke causing it to bottom and since there wasn’t enough rebound dampening it would bounce back with a kick. What I determined it really needed was more dampening and a softer single rate spring. I decided to contact Ohlins USA for assistance since I’ve had great service from them in the past and because they now have Stig Pettersson working with them who is one of the best Ohlins techs in the country. Stig increased the compression by 10% and rebound by 20% and installed black 155 lb springs which were all he had in stock. The springs were still too hard so he ordered me 114 lb springs which I installed. The end result was that the ride was good with only a little bottoming and no wallowing in turns.
Ricor
Greg Benner and I took a ride out to Henderson, NV to visit Ricor at their plant. They spent most of an entire day tuning a set of their prototype shocks to my bike. They fiddled with the valving and spring rates multiple times. I would say they had those shocks on and off my bike probably 20 times until they were satisfied. One aspect of the Ricor shock that really sets them apart is their patented inertia valve. This secondary valve controls rebound dampening allowing the shocks to react to depressions in the roadway very quickly while still exerting sufficient rebound dampening to control the chassis. The result is an extremely plush ride with great control. Because their dampening is so effective in controlling the bike they can afford to use pretty light springs which contributes to the plush ride. In my case I ended up with 100 lb springs which work perfectly even with my wife on board. I ran their prototype units for about two weeks at which time they sent me a set of their production units which ride just as well and even have better control in sweepers than the prototype units had. The end result is that the ride is very good with no bottoming and no wallowing in turns.
Comparison
Since I had both sets of shocks in the garage I figured I’d do a back-to-back test and let you guys know how it all turned out.
Preload Adjustment
Ohlins supplies an aluminum handle that can be used to change preload. The adjusting ring also has a nylon plastic locking screw. This screw is a bit fragile so care must be used when losing or tightening it so as not to strip out the screwdriver slot. First you loosen the screw and then insert the handle in holes in the adjusting ring so you can turn the ring. When you’re done you need to retighten the nylon screw.
Ricor has a very large adjusting ring on top of the spring. They have also included a friction reducing washer between the spring and the perch. All you need to do is to grab the upper ring and turn it by hand. No extra tools are needed.
Advantage = Ricor
Dampening and Ride Height Adjustment
Ohlins comes with a built-in sweep valve that primarily adjusts rebound dampening but also effects compression to a lesser degree. Once the shocks were modified by Ohlins there was sufficient adjustment available to be useful. Being able to adjust the dampening can be an advantage when compensating for a passenger. You do have to remove the bags to get at the valve, though. Ohlins also has a provision to adjust the ride height between 12 3/4" > 13 9/64".
Ricor provides no dampening or ride height adjustment.
Advantage = Ohlins
Appearance
The Ohlins shocks are very nicely machined units but have little in the way of style. The Ricor shocks are hard anodized black with polished highlights and are very stylized and attractive units. I’ve included a picture of them together so you can decide for yourself. I gave the advantage to Ricor because I like what they look like.
Advantage = Ricor
Price
Currently the Ohlins are listed for $875 but Howard offers a discount to forum members. Ricors are currently $630.
Advantage = Ricor
Handling
Even though our bikes aren’t normally ridden like you would a sport bike we still need sufficient dampening in order to have good control in the twisties without excessive bottoming or wallow. Excellent control has always been a mainstay of Ohlins and they certainly don’t let us down in this application. Ricor has been building suspension systems for professional race teams since their inception so good handling shocks come second nature to them. For the benefit of this test I would said it’s a draw.
Advantage = neither
Ride/Comfort
This is one area where there is an obvious winner. I switched shocks no less than three times and ran a 25 mile course that included a piece of SoCal freeway, bumpy secondary roads and back road sweepers. The last run was done with a passenger. While the Ohlins always felt controlled and secure they were at the same time harsh, particularly on sharp edged bumps. The Ricors on the other hand, felt just as controlled and secure but did a much better job of absorbing bumps.
Ohlins = good
Ricor = very good
Advantage = Ricor
Summary
I’ve been messing around with the suspension on this bike for over a year now plus a lot of other bikes since the first time I modified a pair of Triumph Girling shocks to fit my ’69 Honda Four. In the end I think my Road Glide is now the best it is going to be with what is currently available. The real issue is that Harley, even with their new design frame, only allows for a total of 3” of rear suspension travel. The maximum regardless of what shock you use is 3.3” at which point the swing arm hits the frame. Taking into consideration an initial 1” of sag and the installed bump stops built into all shocks, you have less than 2” to really do the work. That just isn’t enough. The result is that all shock suppliers have been and will be hard pressed to really give us a ride on par with other touring bikes in the market like a Goldwing or a Victory.
Having said that, we still try to get the best we can and in my opinion the combination of Ricor’s Intimitators in the front and Ricor’s shocks in the rear is as close as it’s going to get.
Marc
Ohlins on the left and Ricor on the right.
Linking
Old Mar 26, 2010 | 10:19 AM
bmaier's Avatar
bmaier
Great write up
Old Mar 26, 2010 | 11:13 AM
JCleary's Avatar
JCleary
Nice writeup. Thanks!
Looks like I'm going to have to ride to Vegas and get some new suspension
Old Mar 26, 2010 | 11:26 AM
'05Train's Avatar
'05Train
Marc, which tune did you get on the Ricor shocks, comfort or sport?
Old Mar 26, 2010 | 11:37 AM
qtrracer's Avatar
qtrracer
Nice idea on the Ricor Shocks and I am sure that they work well. I was lucky and Howards springs and valving on my Ohlins was spot on for my riding style , but now I need front fork help and will wait until someone posts their experiences on something that costs less than 1300 dollars and works!
Old Mar 26, 2010 | 11:41 AM
'05Train's Avatar
'05Train
A pair of Intiminators will run you around $230 with the forum discount and will dramatically improve the front end feel.
Old Mar 26, 2010 | 11:50 AM
qtrracer's Avatar
qtrracer
Unfortunately thats what they are saying about the race tech gold valves emulators and a guy on here that I knew from my mx race days has them and his opinion is that they are a waste of money, not that they don't work just that they are not worth the money and effort to install and I know this guy can out ride 99% of anyone on anything so I trust his opinion. Not saying the Ricor product is in the same boat but until I hear more I don't want to just throw money at the front end just yet.
Old Mar 26, 2010 | 12:08 PM
Wes10RG's Avatar
Wes10RG
Default Full Ohlins Warrenty when you buy from Motorcycle Metal
NO!
Howard's (aka Motorcycle Metal) Ohlins carry the full factory warrenty. I called Ohlins USA today and they speak very highly of Howard at Motorcycle Metal. He has been trained by them and the adjustments/builds he does have been verified and approved at the factory. They have complete confidence in him plus he is instrumental in many engineering activities that they have ongoing.
Now Howard, that is mighty impressive.
