Dyno runs
Old Mar 26, 2010 | 04:56 PM
redhwk44's Avatar
redhwk44
Originally Posted by Harleypingman
Mark, viewers of dyno sheets can decide for themselves what to make of them. For some, a dynos sheet on a particular cam, SE kit, indy's headwork, etc. is THE holy grail of comparison to other cams, kits, etc.
For others, a dyno sheet is a way to confirm that the engine has been correctly assembled. Since many of the builds are repeat builds (i.e. others have assembled identical or highly simlilar builds) the WOT sheet will validate that the engine has been assembled and tuned correctly. If there is a gross deviation (e.g. the engine puts out significantly less power), that probably indicates a problem such as sumping, misaligned cams, etc. If the dyno sheet shows numbers significantly higher than virtually identical builds (say, 10% higher) from a particular tuner, the numbers may be the result of a dyno that simply reads higher hp and torque (i.e. the tuner isn't manipulating the dyno to generate higher numbers) or the tuner may be manipulating the dyno to produce higher numbers to attrace business for himself or the shop that uses him to tune their builds. In either case, looking at dyno sheets from other tuners for the same or nearly identical builds tends to identify the happy dyno.
As for your repeated question about posting dyno sheets by those who say the numbers don't mean anything, that's more an expression about the specific numbers resulting from a properly assembled engine and sharing with others that information for general comparative purposes.
Taking PhilM's 124 build as an example, Ed could have continued to advance timing and adding fuel in the WOT runs to the point of pinging in each rpm segment from 2K to 6500 rpm and backed off 3 degrees of timing when pingning was detected and had a maximum power tune. However, in July and August when it's much hotter in Dallas, that max power tune would probably ping like crazy because the air would be less dense (less oxygen), and Phil would need to take out some timing to eliminate the tune. As Ed explained, they didn't do a max power tune.
As for folks being "giddy" about PhilM's peak dyno numbers, I wouldn't characterize the comments that way. In any event, there is no denying that PhilM's build is not what we usually see on HDF from one of our own. And I don't see many 130 hp/150 tq Road Glides around. So yes, I'm impressed to see someone take a twin cam motor and produce that kind of power in a streetable touring bike that can deliver 40+ mpg.
You're having a 117" engine built for you. I hope you will do as Phil did and post pictures of how the engine was assembled, what components you used, and how the bike behaves after the engine is installed and you've gotten some miles on it.
Carl
Well said Harley, I believe that most posters , PhilM included , use the Dyno as a bench mark of what they had compared to what they have. I am about to do the Fuel MOto upgrade ( TW-6-6 cams, Header Pipe, PCV and Intake) not much use for a dyno run with that work. But when you do extensive engine work I can see where the dyno is a necessary tool.
Old Mar 26, 2010 | 06:25 PM
qtrracer's Avatar
qtrracer
Dyno #'s are a joke as far as comparisons between bikes unless done back to back on the same dyno same day and then who cares , if the two guys of you want to find out something ,instead of paying the dyno guy find a stretch of secluded road and get it on. The dyno is for tuning and finding what works on your bike.
Old Mar 26, 2010 | 06:32 PM
jag1886's Avatar
jag1886
Dyno's do seem to very one to another, here in Boise there are 2 dyno's in town, maybe 3 but anyway the local Indy says that the local Harley shops dyno reads high, he dyno's bikes that have come from the dealer and they read no ware as high as the dealers readings.
I don't know which one is right but they do vary.
Old Mar 26, 2010 | 06:49 PM
Biggzed's Avatar
Biggzed
Mark -
Plain and simple. A dyno sheet showing "uncorrected" or "actual" hp and tq numbers is always going to be questioned on forums. It's simply reality. I believe this is where this entire pissing match with Phil's thread started and why you created this thread. Without showing SAE correction, as Ed pointed out, there will continue to be questions.
Zach
Old Mar 26, 2010 | 07:23 PM
hog-doc's Avatar
hog-doc
You want to see even higher numbers throw your bike on the dyno drag trailer when it comes back to town, it reads about 15% higher than ours does.
When I was in Colorado we had a few guys that built big inch stuff on a regular basis and traveled all over the west and would dyno thiers in different places. They always complained our DynoJet200 read LOW. I ran my bike in Colorado and ran it again in Idaho when I first got back here on our DynoJet250i, it showed the exact same Tq and 1 HP less! Whats it all mean.................not a damn thing realy!
Old Mar 26, 2010 | 07:49 PM
Dalton's Avatar
Dalton
As others have said, the chart can also be used to verify the build. For example, the last 107 I did I was curious as to whether or not it matched up to others. Not interested in seeing if it was stronger, just in the ballpark and it was, so it validated the build, the components used and the assembly process. When I had my 120, it was not tuned for performance, it was tuned for rideability and fuel economy in the touring rpms. There was no need to go chasing the last 5 hp or Tq as it was so civilized while riding.
When my new bike arrives, I already have a build set for it, and it is going to be quite different that what is usually done, and is an experiment, so it will go on the dyno to see where it ends up as a reference point only.
Point is, the dyno is a tool to use for tuning, and the chart, in my mind is to be used for reference only.
PhilM's Avatar
PhilM
Dude.... That's CLASSIC!!!!!
Old Mar 26, 2010 | 10:30 PM
Mark MPDC's Avatar
Mark MPDC
Originally Posted by Biggzed
Mark -
Zach
So what most of you are saying is that the numbers some people post on here about their builds can be false numbers no matter who the build is done by is that correct?
Old Mar 26, 2010 | 11:21 PM
Mark MPDC's Avatar
Mark MPDC
"You're having a 117" engine built for you. I hope you will do as Phil did and post pictures of how the engine was assembled, what components you used, and how the bike behaves after the engine is installed and you've gotten some miles on it."
Why do you think posting pictures will help in this discussion?
Old Mar 26, 2010 | 11:27 PM
Biggzed's Avatar
Biggzed
Read what you want dude. I hope your having fun.
