Battery slowly draining.
Old Mar 29, 2010 | 03:12 PM
rh8234's Avatar
rh8234
My 04 ultra has the original battery and I started it today for the first time this year after sitting all winter. It cranked right up. You must have something drawing down the battery. Sandcrab gave you good advice about tracking down what exactly it is.
Old Mar 29, 2010 | 03:29 PM
1st 96 ultra's Avatar
1st 96 ultra
if you know it is going to set for a few days just disconnect one of the bat cables [ NEG is always first ] then let it set , when you hook it back up if its dead take the bat back , and you can do the test light test but if you have a sec. system it will show a draw
Old Mar 29, 2010 | 03:36 PM
jimsflh's Avatar
jimsflh
I'd take the battery out, charge it fully, take the charger off and check it every hour for 3-4 hours, if it's not holding it's charge, (12.8v I believe) take it back while it's still under warranty. If it is it's definately sounding like a short somewhere.
Old Mar 29, 2010 | 05:40 PM
psychocircus's Avatar
psychocircus
i was told that if the kill switch is in the run position it draws some power, make sure you turn the kill switch to the off setting
Old Mar 29, 2010 | 08:18 PM
mackcr's Avatar
mackcr
I had the exact same problem on my 06 Ultra last year. Purcahsed a new battery and in a couple of days of not riding and it was dead too.Turned out to be the stereo was constantly drawing power. Once that was swapped out on warrantly I have had no more issues.
Old Mar 30, 2010 | 06:49 AM
kyote's Avatar
kyote
Fully charged is 13.8v
Old Mar 30, 2010 | 06:56 AM
soundman's Avatar
soundman
13.8 is with the bike running. This is what the charging system should be putting out.
Old Mar 30, 2010 | 09:20 AM
jimsflh's Avatar
jimsflh
Yep, I agree with you agreeing with me
Old Mar 30, 2010 | 09:53 AM
kyote's Avatar
kyote
Ooops...thats right.....had a brainfart..lol
Old Mar 30, 2010 | 10:57 AM
big cahuna's Avatar
big cahuna
your security system draws a small amount of power, as does the radio when the bike is off. The part that keeps the radio presets and clock. Both are very small drains. Have you added an accessories to the bike that need to be manually turned off?
Browning, nb
2014-2024 Touring Models
18
Apr 22, 2015 12:00 PM
HKSkully
May 6, 2013 10:18 AM
fxrtfan
EVO
13
Aug 20, 2011 05:31 PM
2002FLSTFBAGGER
EVO
13
Jul 13, 2011 07:12 AM
Johnsonr
Feb 18, 2011 07:54 AM
