Bad vibration
Old Apr 1, 2010 | 10:06 PM
david christopher's Avatar
david christopher
Originally Posted by Sancho
Check the bolt connecting the bottom front of the engine to the frame. I had an '01 Ultra and checked mine and the bolt was about ready to fall out. I do not recall the torque spec. A dealer wouldn't charge much to check your motor mounts if you don't have a service manual.
Thanks Sancho, will check tomorrow
Old Apr 1, 2010 | 11:58 PM
twistedcherokee's Avatar
twistedcherokee
Originally Posted by BadPiggy
Motor mounts?
Something is telling me to check your crank.
Scissored?
If the vibration isn't in the primary where you replaced those parts...I just gotta hunch.....
What do you mean scissored? Thanks
Toby
Old Apr 4, 2010 | 11:45 AM
twistedcherokee
Got it back together last night, no vibration. Other than the socket that I found between the engine & the frame, all I did was readjust the primary chain to the 5/8" cold.
Toby
Old May 30, 2010 | 12:10 PM
tgaetto's Avatar
tgaetto
Always have to look at everything....I was having the Vibe/shutter at 3k too, unfortunately I had just put in Sta-BO bushings found my rear fork caps loose and reworked the exhaust mount to the trans (never ever did it clamp and now it does). After all of that the shutter became very noticeable so as one can imagine I was unsure at which fix caused the "new" vibration.
I was very worried about run-out and/or the motor mount so I checked both. What it turned out to be was the front exhaust tube hitting the brake pedal. I ground a little out of the pedal and the shutter is gone. I had always had a vibration but it was totally amplified and I felt it through the pegs, boards and seat.
lou1
Oct 5, 2010 08:05 AM
37 Jonz
Jun 24, 2010 09:08 PM
mplecha
Exhaust System Topics
Mar 30, 2009 08:33 PM
OCD
Jan 4, 2007 09:04 AM
exhdo1
Sep 13, 2005 05:30 PM
