Rinehart Install
Old Aug 5, 2006 | 12:50 AM
Stumpman's Avatar
Stumpman
Default Rinehart Install
Man this is a bigger job then I thought. It's mostly time consuming. I got the old pipes off and will install the new ones tomorrow then off to the dealer for the SERT and Stage one a/c and Dyno. Can't wait!
Old Aug 5, 2006 | 01:35 AM
swb's Avatar
swb
Default RE: Rinehart Install
What problems did you encounter? I am going to do the same thing in the next month and any tips would be appreciated.
Old Aug 5, 2006 | 02:34 AM
99RoadKing's Avatar
99RoadKing
6th Gear
I talked to a Tech friend of mine and he says that although he loves Rineharts, all of the Techs hate to put them on. They are the biggest PITA in his words!
Old Aug 5, 2006 | 04:19 AM
2smoooth's Avatar
2smoooth
Buddy and I.. 3 hours start to finish (including PCIII and Stage 1)
I think it took more time getting the OEM ones of the bike [:@]
Old Aug 5, 2006 | 04:56 AM
mikeisglidn's Avatar
mikeisglidn
they're not too bad to install, take your time, and when your done it will be worth the effort!! guod luck
Old Aug 5, 2006 | 09:36 AM
wnogood's Avatar
wnogood
I put mine on the other night. Yes, they are a little more time consuming than the VH duals and slip ons. I had the stockers off, rineharts on and running in 2 hours. Let me tell you a trick I learned......
Take the left muffler off first, heat shields next, left pipe, take the right floorboard loose, unbolt the 2 pipes from the heads and pull all that $hit off together. I was really dreading the removal of the stock pipes but after looking at it, and deciding on a different approach, it worked really well. As far as the install on the rineharts, just like anything else.....do not tighten anything until you have it aligned and straight like you want, and then gradually tighten things up......
nogood o~`o
Old Aug 5, 2006 | 10:44 AM
Stumpman's Avatar
Stumpman
Thanks for the info on the install. I took the old ones off already. They were a pain getting thm off the engine, I used a rubber mallet and still couldn't seperate them so I removed the two header pipes as one piece like said in an above post it worked a lot easier that way. I don't think the rineharts will be as bad going on as the stock ones were coming off. I can't wait to hear how they sound.
Old Aug 5, 2006 | 01:00 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
SAWZALL!
Old Aug 5, 2006 | 04:21 PM
jpnelson1978's Avatar
jpnelson1978
pay attention to the directions very close, get it right down to every bolt and washer, also before you start, make sure you take the stock gaskets out of the headers, i and a few others made this mistake, its very easy to pass them by, the stock gaskets really blend well in the headers. go to a local hardware store and replace the stock flange nuts with steel lock nuts. the stock nuts that they want u to reuse will keep loosening up on you, so i used locking nuts instead ( do not use nylon locking --too hot! you need steel lock nuts) do not get ahead of yourself, take one step at a time!
Old Aug 5, 2006 | 07:47 PM
BadX's Avatar
BadX
ORIGINAL: Neggy ZRXOA 5248
SAWZALL!
sounds like something I would try[8D]
