Why two different types of sparkplugs?
Old Mar 30, 2010 | 06:23 PM
blueduramax's Avatar
blueduramax
Default Why two different types of sparkplugs?
While getting to know my 2004 Road King Classic I discovered that the front cylinder has a 10R12A plug and the back cylinder has a 6R12 plug. Is there a logical reason for this and should I change them to 6R12's? The front one seemed a little wet and they both looked like they were pretty old.
Old Mar 30, 2010 | 06:28 PM
ashmarc's Avatar
ashmarc
Stock plugs for my '06 Ultra are the 6R12's........not sure why you would have different ones......
Old Mar 30, 2010 | 06:43 PM
BamaVan's Avatar
BamaVan
Somebody prob just replaced it with wat was available at the time
Old Mar 30, 2010 | 06:48 PM
jimsreddyna's Avatar
jimsreddyna
I don't know if the 10r is a colder or hotter plug than the 6r? Maybe the front cylinder was running a little hot or it was fouling out so they tried to compensate with a different heat range plug?
Old Mar 30, 2010 | 06:54 PM
dawg's Avatar
dawg
V-rods and Buells run the 10R12A's as stock. TC's run the 6R12's
Old Mar 31, 2010 | 03:56 AM
emwolb's Avatar
emwolb
used to be an old trick on the nucks, pans, etc, to use a different heat range on the rear cylinder because it didn't get as much cooling air. in todays world though, 6R12's work just fine. and don't buy into any of that crazy gimmick three electrodes, splitfire or any of that crap. 6r12's work.
Old Mar 31, 2010 | 06:09 AM
VETERAN75's Avatar
VETERAN75
Looks like it may have been all he had when he really needed on.
cameron.m
Oct 2, 2018 12:27 AM
HDF Tech
Engine Mechanical Topics
Apr 2, 2015 05:56 PM
MyRide7
Jun 11, 2009 07:07 PM
Fox
Aug 7, 2007 06:47 PM
mtnlvr
Exhaust System Topics
Feb 4, 2007 04:35 PM
