Wheel Locked Up
Old Mar 30, 2010 | 08:08 PM
Willy67's Avatar
Willy67
Stage IV
Default Wheel Locked Up
Took bike out of storage tonight and the rear wheel lock up. I park on a slight incline and leave it in first gear. I got on the bike, engaged the clutch, shifted into neutral moved back about 1-2 feet and the rear wheel locked up. Started the bike and was able to put it in gear and move forward to original spot. Repeated the process again, this time got a little further and wheel locked again. Any ideas? I don't want to force it.
Old Mar 30, 2010 | 08:16 PM
NoCoLoco's Avatar
NoCoLoco
Is the wheel locked when the clutch lever is pulled in?
Old Mar 30, 2010 | 08:17 PM
bigskyhd's Avatar
bigskyhd
You don't have a rotor lock in it that you forgot to remove do you? I've seen that actually happen. Or perhaps something is on the floor blocking movement? Wierd for sure.
Old Mar 30, 2010 | 08:21 PM
Araba Shriner's Avatar
Araba Shriner
A wheel lock was the first thing that came to my mind. Maybe a wheel bearing, did it click or make any noise?
Old Mar 30, 2010 | 08:23 PM
Willy67's Avatar
Willy67
Stage IV
No rotor lock. The clutch was engaged the entire time that I tried to break it. There was a slight click.
BC Glide's Avatar
BC Glide
Wheel lock was my first thought as well.
SICKBAGGER's Avatar
SICKBAGGER
He did not come back must of been the wheel lock again!!!!!
o0smitters0o
13
May 8, 2018 07:41 AM
paco12
Feb 18, 2018 05:05 AM
tcarson84
Apr 12, 2016 06:12 PM
outkast76
Jan 29, 2016 02:47 PM
Cakes
Sep 2, 2007 08:35 PM
