Wheel Chock
Old Apr 18, 2010 | 02:55 PM
QQVEPY's Avatar
QQVEPY
I have 2 Condors. I have bought other things from Harbor Freight that were less than optimal quality. I just don't want to chance it with nearly $30K in bike and parts.
Old Apr 18, 2010 | 03:22 PM
TheShrink's Avatar
TheShrink
Originally Posted by Casper
tried to post a picture, but not happening ???
http://www.harborfreight.com/cpi/cta...emnumber=97841
this is a link to it...
This is the one that I have bolted to the HF Air lift. I did cut & widen the "rocker" part 3/4" and it's now works like a charm. Easy on, easy off!
Old Apr 18, 2010 | 08:31 PM
red.heritage's Avatar
red.heritage
Something to consider ----
I had a BikePro and the Harbor Freight knock off of the BikePro. Both worked well with my Heritage Classic.
However, I was in for a surprise the first time I transported my new Ultra Limited. My legs are too short to get the front wheel up and over the pivot bolt on either of them.
I bought a WheelDock and the problem was solved. The WheelDock is the only chock on the market (that I am aware of) that does not work with a pivot bolt. It uses gas cylinders to close onto the wheel.
I am very satisified with the WheelDock.
Old May 26, 2010 | 09:57 PM
mcain49's Avatar
mcain49
Just got the Condor for my FLH. Works great as a free stand in the garage and holds the bike like a rock. Makes checking fluid levels and working on the bike much easier. Great quality, finish and light weight (21 lbs.) Also got the trailer adaptor which makes it easy for one person to trailer and tie down. Only drawback to this stand is its a little pricey.
Old May 26, 2010 | 11:52 PM
HD66FLH's Avatar
HD66FLH
if you are going to haul and chock it, protect the rubber on the tire from the chock. if hold-downs give a little and the bike shifts to either side, it can wear a hole in the tire. put an old cloth, carpet or whatever between both sides of the tire and the chock.
Old May 27, 2010 | 11:34 AM
BigDog1954's Avatar
BigDog1954
I have a Condor and use it as free stand in the garage and move to the trailer when needed. Love it.
Old May 27, 2010 | 04:04 PM
shagnasty's Avatar
shagnasty
I got the Harbor freight unit also. Works great in the garage and in the truck bed. Forget those high dollar units! That doesn't mean they are any better. They are all made in China! But hey, all the good stuff is now! And the bad!
Old May 27, 2010 | 04:14 PM
jpglide's Avatar
jpglide
I am very satisified with the WheelDock.[/QUOTE]
+1 Wheeldock is sturdy and works great.
Old May 27, 2010 | 08:22 PM
BillyG0856's Avatar
BillyG0856
I have this one from Harbor Freight. Works great on my trailer....also mounted it to a 2X2 piece of 3/4" plywood for mounting to my 'shop' floor. I bought 1/4" anchors....put them in the shop floor. When I want it there, I just put it down with the bolts. Works Great!!! The plywood gives that little bit needed to get the Craftsman M/C jack under the bike.
Billy G
S.D.M.F
Nov 7, 2018 09:20 PM
RATE
Apr 30, 2015 01:19 AM
EasternPC_Forum
Dec 11, 2013 03:54 PM
sbbrown
Mar 9, 2007 03:14 PM
