Gps mounts
Old Apr 12, 2010 | 07:52 AM
  #41
Quadancer's Avatar
Quadancer
Hey, if you don't use the windshield, then why not bolt some stainless allens thru it? Might give it a bit of a tough look if you do it right. Use rubber washers next to the plastic so it doesn't crack.
Old Apr 12, 2010 | 08:54 AM
  #42
Texas Fat Boy's Avatar
Texas Fat Boy
Ram-Mount
I use this one that uses the mirror stem, but if you don't have a mirror you could bolt it on.
To me, it keeps the handle bars looking cleaner when you don't have it on.
Old Apr 17, 2010 | 08:55 AM
  #43
camadon1971's Avatar
camadon1971
Where did you get the strap mount you have? That sounds like what I am looking for.
Old Apr 17, 2010 | 03:02 PM
  #44
boardy's Avatar
boardy
Got this system to mount my Tom Tom Rider and also added the ultra tilt. Very good quality and nice people to deal with.
http://www.leadermotorcycle.com/PROD/EDHD-GPS-NUVI.html
Regards,
Chris.
England.
Old Apr 17, 2010 | 03:49 PM
  #45
Harley_RN's Avatar
Harley_RN
I hard wired mine to the Kuyakyn Fuel door mount. I'm using a Garmin 765T and a RAM mount with a couple of mount convertors. For the power, I wired into the HD accessory connection by taking off my console and using an aftermarket hard wire 5 volt to 12 volt converter. If you look in the wiring diagram you can use this connector without having to use the switch on the console. My GPS turns on when I turn on the ignition and the accessory switch is still in the off position. I like that my GPS is right in front of me and doesn't vibrate like it would if mounted to the handlebars. I feel this is a better mount than on the handlebars as it is in my line of sight as if I was looking at my speedo or my tach. I only have to look straight ahead at the 12 o' clock position and then down to 6 o' clock to see the GPS. The GPS is closer to my field of view and I can see the screen instantly. If you need more information for the mounts and how I wired this up, send a PM...
Attached Thumbnails Gps mounts-014.jpg   Gps mounts-015.jpg   Gps mounts-016.jpg   Gps mounts-017.jpg   Gps mounts-018.jpg
Old Apr 17, 2010 | 04:36 PM
  #46
Quadancer's Avatar
Quadancer
Here you go:
http://www.amazon.com/gp/product/B00...9V86E059X83ZR4
Old Apr 17, 2010 | 05:23 PM
  #47
2D3K1H1B1HIM's Avatar
2D3K1H1B1HIM
Well guys it seems that this is an open topic with a million answers....I finally chose to mount the powerbar plus with a ram 3" arm and new cradel....sets it up close to eye level but its still off to one side,guess Ill get adjusted in time .....thanks far all the responses
Old Jan 26, 2011 | 11:48 AM
  #48
wtkpga's Avatar
wtkpga
Thanks, these are some great ideas.
Old Jan 26, 2011 | 12:00 PM
  #49
Shrug's Avatar
Shrug
I agree with HarleyRN. I mounted my 660 on the fuel door using the Kuryakyn kit. I ran the wiring under the tank console to the fuse box so I can remove the fuel mount if I like. I also installed the keyless fuel door button. Since any barrel key will open it, it was pretty much useless.
Old Jan 26, 2011 | 11:36 PM
  #50
Potato_Potato's Avatar
Potato_Potato
Now you see it
Now you don't
