Leaking fork?
Old Apr 6, 2010 | 07:26 PM
wsaxton's Avatar
wsaxton
Default Leaking fork?
I took my 2009 Ultra with 6400 miles into the shop last Friday because I thought the left fork was leaking from the top of the larger diameter section. The chrome section of the fork would get oily right after I washed the bike or wiped down the fork leg. With in 100 miles there would be several streaks all the way down the chrome section of the fork. The problem started after my 5000 mile service from the same dealership. Anyhow the dealer called me today to tell me that there was no leak in the fork. What I saw was grease melting and running out of my "neck tube". Not sure if this is what it is actually called but on a bicycle I know they are called head tubes. The service rep told me at the 5000 mile service the pumped the neck tube full of grease and as it melts it runs out. Mine just happens to run down the outside of my chrome fork leg. Is this common? The bike did not do this from the factory. It is not hot yet here in Houston 80 degrees max, as soon as we get into summer we will get to 100, what then? Did the dealer put too much grease in? Maybe an inferior grade of grease that melts at extremely low temps, I do not know. In any case the explanation seems week and results, an oily fork leg after 100 miles of riding, are just completely unacceptable. Let me know if this is normal or common.
Thanks
Bill
Old Apr 6, 2010 | 07:37 PM
lp's Avatar
lp
This is very common. They are not feeding you a line of bull. For one "fork fluid" is red.
One thing that might help is to turn your forks and scrape all the excess goo out from around your neck and lower triple tree.
lp
Old Apr 6, 2010 | 07:38 PM
Dionicio's Avatar
Dionicio
Yep, it's common. You just got to keep it clean.
Old Apr 6, 2010 | 08:06 PM
CroK's Avatar
CroK
And not all 'fork fluid' is red...
Mine is the color of 30wt. oil. And yes, it is true fork oil, made by belray.
Old Apr 6, 2010 | 08:21 PM
hog-doc's Avatar
hog-doc
Iam pretty sure lp was speaking of OE fluid.
Yes its common on bikes that get pumped full, yes it will start to melt around 80 degrees.
Old Apr 6, 2010 | 08:41 PM
1flhtk4me's Avatar
1flhtk4me
Wipe off the top of the lower tripple tree.There are pockets casted in and these will puddle up with grease.
mmullins2000
Oct 14, 2014 04:50 PM
Lucky1359
Jul 3, 2014 07:04 PM
RoadHog659
Mar 16, 2010 09:01 PM
DWhite
Apr 22, 2008 03:52 PM
HDF Tech
Jun 25, 2005 11:42 AM
