Sreamin Eagle heads
Old Apr 19, 2010 | 08:42 AM
phat96's Avatar
phat96
They say the CV is easier to tune or adjust, for a lot less money.
Old Apr 19, 2010 | 10:43 AM
hog-doc's Avatar
hog-doc
Save the heads for when you do the big bore, if you remove the heads you need to pull the cylinders and replace the base rings so you might as well do it all at once.
As far as CV/Mikuni, while the CV can be fixed to run right the Mikuni IS a BETTER choice, better throttle response, better ridability, more adjustability.
If you do use a CV, DO NOT use a Dynojet or Thunderslide kit, they are a waste of money. Drag has a jet kit that works great, part # DS-195100. Comes with a new needle and emulsion tube and jets, unfortunatly it doesnt come with a 185 mian jet that most mild combos need but you can get that at the dealer part #27185-90, run the 45 pilot and start the mixture screw at 1 7/8 turns out.
Beau Bunch
Feb 22, 2019 05:00 AM
Baja555
Mar 4, 2018 07:53 AM
cbaker1@farmersagent.com
Engine Mechanical Topics
18
Nov 1, 2016 09:06 PM
mike06train
Jul 28, 2009 10:08 PM
2stout4u
EVO
Oct 31, 2006 01:50 AM
