Clutch cable ? For dawg
Old Apr 12, 2010 | 07:52 AM
ANIMAL03's Avatar
ANIMAL03
Default Clutch cable ? For dawg
yes i read the book but. maybe i missed it. do you have to back out the adj on the clutch hub when replacing the clutch cable. thanks in advance .
Old Apr 12, 2010 | 08:21 AM
dawg's Avatar
dawg
When changing a clutch cable I like to do a full clutch adjustment at the basket at the same time after the new cable is installed. As far as having to back off the adjuster in the basket prior to swapping the cable, no. Swap the cable then adjust the basket, then adjust the cable.
Old Apr 12, 2010 | 09:07 AM
ANIMAL03's Avatar
ANIMAL03
thanks dog. you are the man.
Old Apr 12, 2010 | 10:24 AM
hog-doc's Avatar
hog-doc
If the ctuch was adjusted properly there is no need to readjust the center screw at the hub. Nothing changes in the ramp/ push rod/ center screw length from a cable R&R.
You will however need to readjust the cable after about a 100 miles from initial stretch.
Richard Winquest
EVO
Jun 15, 2017 06:45 PM
gliderman
Jun 5, 2014 10:39 AM
thundergod
Sep 13, 2011 08:24 PM
srigas
Dec 17, 2009 08:57 AM
skos
Oct 23, 2008 03:46 PM
