SE-204 Cam and dyno
The pros are, it increases lift just a little, which should help cylinder fill. The downsides are... if you've added too much lift, it can slow down the intake charge, which will hurt performance.
You want just enough of a valve opening to keep the charge moving as fast as possible, and enough of an opening to allow as much fuel in as the motor needs. Not enough, and you're losing power by not allowing enough fuel. Too much, and you lose power by slowing the intake charge, actually reducing the amount of fuel that goes into the combustion chamber.
I went with the non roller rockers. At the modest lift we're talking here, roller rockers aren't really called for. If you're running big lift cams, and high rpm motors, then roller rockers can help valvetrain lifespan and efficiency.
Add them if you have the extra funds. What are the specs of your build?
