gps power
Old Apr 13, 2010 | 06:25 PM
2010 ultra man's Avatar
2010 ultra man
Default gps power
I have a 2010 FLHTK. Is it o.k.to plug my G.P.S. into my cigarette lighter on the fairing for power?
Old Apr 13, 2010 | 06:28 PM
NoKenDo's Avatar
NoKenDo
It is ok. Just make sure the plug doesn't hit anything when you
turn to full lock. If you take your outer fairing off you can
tie into power there.
Old Apr 13, 2010 | 07:00 PM
Harley_RN's Avatar
Harley_RN
According to the manual:
"The lighter is not intended to be used as a power port for electrical devices. Damage to the lighter receptacle may occur."
If you use the search engine, you'll find several cool threads on how to hard wire your GPS.
Old Apr 13, 2010 | 07:13 PM
Bradley Jones's Avatar
Bradley Jones
I've used it to charge my phone and power my gps. 10k miles doing this it hasn't failed yet. only problem is with the big plugs in it you can't turn to lock the steering. One day soon I'm going to hardwire a female panel mount jack on the inner fairing and cut my gps cord down short with the same size male jack to match. In other words..............
Just do it.
Old Apr 13, 2010 | 08:15 PM
SC_Compact's Avatar
SC_Compact
I bought a hardwire off ebay for $10, went to Walmart and and bought a cigarette lighter plug for $2. Cut the hardwire down to about 12 inches, soldered and shrink wrapped the two together. I just plug it in when I want to use my GPS. No extra wire and the plug does not hit the tank even at full lock. If you decide to do the same maker sure the plug has a built in fuse and make sure you use a 3 amp fuse. The one I got came with a 5 amp fuse and i replaced it with a 3 amp.
Old Apr 14, 2010 | 07:34 AM
nvsteve's Avatar
nvsteve
I've used mine to power a 12 volt compressor. No problem.
Old Apr 14, 2010 | 07:40 AM
Avalanche_Mutt's Avatar
Avalanche_Mutt
I bought my hard wire kit from the Ram mount guys and wired it in to the 12v in the head light then poked the end through the clutch hole.
Old Apr 14, 2010 | 07:47 AM
CruzN's Avatar
CruzN
Default Hardwired
I bought a hardwired USB cable then wired it to the back of the cigarette lighter inside the fairing. Ran the USB plug out from inside the fairing.
Works great on my GPS.
Old Apr 14, 2010 | 07:52 AM
FLS2FLH's Avatar
FLS2FLH
I'm with alot of the guys here - don't bother with plugging the cable into the cig lighter and having it dangle. Take the outer fairing off and splice into the 12V at the cig lighter. You can purchase a hardwire cable from www.mountguys.com and the correct butt splices at Radio Shack. This entire job will take you 30 minutes max and make you happier in the long run with the clean look
Old Apr 14, 2010 | 04:28 PM
Badbagger's Avatar
Badbagger
Use a Powelet. The BEST and clean, tis what I'm using and does a great job. Do a search. Not cheap, but damn good.
