Slip on help
Old Apr 23, 2010 | 08:58 PM
munch34m's Avatar
munch34m
Default Slip on help
OK Gang, talk me into doing it myself. I got my new slip ons yesterday. B & E performance with the 2 inch baffles. What tips, tricks or experiences can you share to make my slip on swap easier. Any special tools needed, or does one make it easier than the other? I've never done this before, have the service manual and am quite sure I can master this one.....I think.... ....talk me into it
Old Apr 23, 2010 | 09:20 PM
shagnasty's Avatar
shagnasty
One of the easiest mods you could do. Simply loosen the clamp at the header and remove the 2 screws holding the rear of the exhaust on the saddlebag supports. grab the muffler and pull, shake, rotate til it comes off. reverse process to install.
Old Apr 23, 2010 | 09:27 PM
djracing's Avatar
djracing
6th Gear
Nothing to it like shagnasty said.Just check to make sure the same length sticks out past the bags evenly when your done.
Old Apr 23, 2010 | 10:08 PM
acchd's Avatar
acchd
Get you tube of Permatex Ultra Copper Maximum Temperature RTV Silicone. Some replace there clamps with new ones.
Old Apr 23, 2010 | 10:35 PM
NoCoLoco's Avatar
NoCoLoco
You'll need a couple cold ones.
Old Apr 23, 2010 | 10:39 PM
Craig4711a's Avatar
Craig4711a
Like Shagnasty said.... pull, twist, yank, wiggle up and down, left to right, tug until the thing comes off. New one goes on easier than the old one comes off. I put the two hole bracket on sideways to have a handle for pulling. Seem to remember the right side was harder than the left side. Go for it.... you'll be glad you did it when it's done.
Old Apr 24, 2010 | 12:22 AM
dirtracin23's Avatar
dirtracin23
+1 on the Ultra Copper RTV. I would also recommend using some penetrating oil to aid in the removal of the old mufflers. Be prepared. Both could come off easy, one could be easy while the other is difficult, or both could be a major pain in the ****. I have used the old clamps over with no problem and the RTV will help eliminate any of those pesky small exhaust leaks. It's nothing you can't handle and you'll save money and get some satisfaction from doing it yourself.
Old Apr 24, 2010 | 03:57 AM
WannaBuy's Avatar
WannaBuy
1/2" socket for the two bolts in the rear and 9/16" for the clamp. I just did mine yesterday took less than two beers.
Old Apr 24, 2010 | 04:48 AM
ybnorml's Avatar
ybnorml
Like others have said....it really is a 'simple process' along with helpful hints
from others that have already done this.
I have an anxiety attack anytime I touch a tool anywhere near my bike....
cause I know Murphy's Law and I'm clumsy.
I changed my slip ons myself shortly after purchase........So basically what
I'm saying is ; " if I can do it, you should have no problems !! "
Old Apr 24, 2010 | 05:01 AM
carltex's Avatar
carltex
You will need a ft./lbs. torque wrench and some sockets. It's really easy job. On my superglide the hard part was getting the old mufflers off. Took 15 or 20 minutes to wiggle that one off but may be easier for you. You'll be proud of yourself once your done. Then your confidence will grow enough to take on a handlebar or grip change maybe.
