Bullet front turn signal install
Old Apr 24, 2010 | 10:36 AM
rcdifalco's Avatar
rcdifalco
Default Bullet front turn signal install
I have a 2009 Ultra and want to install bullet front turn signals. Need help with install since no instructions with new parts. Do I need to separately purchase connectors, how to wire with highway lamps, etc. Anyone perform this upgrade that can help me through it?
Old Apr 24, 2010 | 10:54 AM
'05Train's Avatar
'05Train
I replaced the lamps and signals with the kit that eliminates the crossbar. It came with the splices necessary to connect everything. You may want to check the P&A site to see if the instructions are there.
Old Apr 24, 2010 | 11:25 AM
Pezz's Avatar
Pezz
The leads on the new bullets should already have the proper connector pieces on them. You need to remove the current wire leads from the plastic connectors inside the fairing and slide the new leads in. Easier said than done. I have done this to a few bikes and have haad to just clip the wires and solder. Either way it works well.
Badbagger
Dec 31, 2019 09:27 AM
rustybit
Jun 12, 2016 01:11 PM
1960lespaul
Apr 13, 2012 08:37 AM
redmustang1990
Mar 8, 2009 01:59 AM
monza66mo
Jul 20, 2007 03:24 AM
