taller gear
Old Apr 25, 2010 | 09:41 AM
ncdan's Avatar
ncdan
Default taller gear
I have an 03 electri glide classic an want a litle taller gear however dont want to spend the money for a 6 speed trans. on a 03 bike. I ordered a 33 tooth front pulley to replace the stock 32 tooth. At 70 mph I am tacking 3000 rpms.and have been told the 33 should drop rpm to 2700. has anyone done this and can offer any advise. I have s an s 510 cams,sampson slipons k an n air cleaner an dynoed at 76 hp. I weigh 165 an wife 130 so I dont think I will suffer any horse power issues. advise pro or con welcomed. Thanks in advance.
Old Apr 25, 2010 | 02:40 PM
qtrracer's Avatar
qtrracer
I have no personal experience however my math tells me you will drop about 100 rpm not 300.
Old Apr 25, 2010 | 04:46 PM
grbrown's Avatar
grbrown
Any change like that is a case of simple arithmetic. Use 33/32 to find the new speed you will be travelling at for given revs, or 32/33 to get the figure you mention. So from 3,000rpm with your old gearing, you will now be running 32/30 x 3,000rpm, or 2,909rpm (not 2,700).
Old Apr 25, 2010 | 04:51 PM
Beemervet's Avatar
Beemervet
Doesn't sound like it's worth doing it that way.
Old Apr 25, 2010 | 09:04 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
on my 05 i thought the same thing, i think it could have used a taller primary without a problem had plenty of power to get off the line and would have loved to dropp the rpm to 2700 at 70 think that would be perfect gearing.
JW7736
General Topics/Tech Tips
16
Apr 24, 2017 04:50 PM
FLS103
Aug 12, 2016 10:37 PM
6speed
May 3, 2009 07:59 PM
markrumsfield
17
May 19, 2008 03:36 PM
mikeAZ
Apr 11, 2008 10:36 PM
