Iphone with Griffin AutoPilot
Old Apr 25, 2010 | 11:54 AM
sgdiesel's Avatar
sgdiesel
Default Iphone with Griffin AutoPilot
Added this solution today and I am really pleased with it.
Griffin make a charger for the IPhone, the AutoPilot
http://www.griffintechnology.com/products/autopilot
So, what makes it so special in this case:
1. The head is really compact so you can simply insert in the batwing cig lighter socket without sweating that it will be crushed at full lock, there is still a small clearance
2. There is a seperate 3.5mm take off in the head of the device, so you can feed that in to the Aux of the HK headset and you are fully connected. This means you only run the single IPhone connector to the IPhone and that takes care of charging and bring the sound back
3. There are buttons (basic I agree but better than nothing) for play / Pause, forward "wind" and "rewind". These are big and can be operated with a glove on
I have my Iphone in a ram mount and only a single lead going to the Iphone
Very neat
Old Apr 25, 2010 | 12:19 PM
MassHD's Avatar
MassHD
Any pic of the set up?
Old Apr 25, 2010 | 12:26 PM
jgreg65's Avatar
jgreg65
WOW great find, thanks for the information
Old Apr 25, 2010 | 01:46 PM
sgdiesel's Avatar
sgdiesel
Not sure pic will help much but this is about all you see of the wiring
It is a very compact device
Old Apr 25, 2010 | 08:42 PM
scooplove's Avatar
scooplove
Still have to mount the device somewhere...
Old Apr 25, 2010 | 09:58 PM
bobros's Avatar
bobros
Thanks for the info.
Old Apr 26, 2010 | 03:19 AM
sgdiesel's Avatar
sgdiesel
As stated in the OP, I use a Ram Mount in the bars which I am happy with. Very common solution to that problem, but not really what the post was about.
This device allows you to run a single cable to the IPhone and connect to the Aux in the stereo and charge. Much neater
Old Apr 26, 2010 | 04:59 PM
sgdiesel's Avatar
sgdiesel
Finished up the install today. I know you can pull the AUX connection through the back of the headset and that would be neater but I am reluctant to pull the headset apart so I opted for the face entry.
I ran the cable in the gap under the headset
I had to modify the 3.5mm jack cable connector at the charge side as it is a bit tight in that corner of the fairing. I trimmed back the plastic support and created a compact 90 degree bend. Very pleased with the results and the basic control of the ipod functionality is very easy with gloves on
Attached Thumbnails Iphone with Griffin AutoPilot-dscn1640.jpg   Iphone with Griffin AutoPilot-dscn1641.jpg   Iphone with Griffin AutoPilot-dscn1642.jpg   Iphone with Griffin AutoPilot-dscn1643.jpg   Iphone with Griffin AutoPilot-dscn1644.jpg
Old Apr 26, 2010 | 05:04 PM
MassHD's Avatar
MassHD
That's the pics I wanted to see. Nice job!
Old Jun 11, 2010 | 05:05 PM
bluesmanjesse's Avatar
bluesmanjesse
I have the new Boom Audio Magnetic tank mout bag for the Iphone/Ipod,I think it would work well with this setup too.
