Cam Swap Noise
Old Apr 26, 2010 | 10:27 AM
Cohiba_Joe's Avatar
Cohiba_Joe
Default Cam Swap Noise
I posted this in the Dyna section. I also posted here since I know there have been many upgrades done on the touring bikes....
Over the weekend I finished up doing a cam swap on one of my buddy's bike. He's got an 01 Wide Glide and we went with the entire swap over - Andrews 26N cams, Torrington inner bearings, updated Harley cam support with oil pump, hydraulic tensioners, roller chains, Harley "B" lifters, SE EZ-Install pushrods, S&S standard rockers and new shafts, etc.
Bike fired up great and ran outstanding. My buddy was extremely pleased however when he came back from the test ride he mentioned that he heard a "different" kind of noise. I listened to it in the shop with the bike idling and to me it has a soft "whooshing" type sound. I then used both a static and amplified stethoscope to double check and it's coming from the cam cover area. No tapping at all.
My speculation is the noise difference is from changing out from the stock "silent chain" and old spring tensioners to the new style roller chain and hydraulic tensioners. Can anyone validate this or noticed the same type thing when you did the cam support upgrade??
Thanks much,
Brian
Old Apr 26, 2010 | 11:51 AM
petemac's Avatar
petemac
pm dawg, Dalton or PhilM, I'm sure they can help shed some light.
Old Apr 26, 2010 | 11:54 AM
adlerx's Avatar
adlerx
The new style cams definately have a whooshing sound coming from the cam chest. I've had two bone stock 08's and both had it off the showroom. Really, you can't hear it when riding. If you can then maybe you got something else.
Old Apr 26, 2010 | 11:59 AM
BigDaddyMike's Avatar
BigDaddyMike
I just replaced my OEM cams with Andrews 37H, Torrington bearings and used the OEM cam plate with a new chain. Little more noise than stock, definitely 'different' but no more than I expected. If everythings tight and sounds ok, Ride like you stole it!
Old Apr 26, 2010 | 12:31 PM
Cohiba_Joe's Avatar
Cohiba_Joe
Thanks guys...
That's exactly what I was thinking and told him in that direction. Based on what he said the noise never changes at highway speeds and can't really hear it.
Old Apr 26, 2010 | 10:25 PM
Mike's Avatar
Mike
MIke, did you buy the inner bearing puller from George's garage or did you go with the cheap-o blind spot puller from HF or somewhere else?
Old Apr 26, 2010 | 10:52 PM
BigDaddyMike
I took it to my wrench and paid him...I can do a lot of things, but..I know my abilities (or lack there of!)
Old Apr 26, 2010 | 11:08 PM
Mike's Avatar
Mike
sorry, I misunderstood your post. Just wondering about the effectivness of the autozone/HF puller. I think I'm just going to go ahead and order it from HF.
ThisIsMe
Sep 21, 2014 06:59 PM
ultraclassic53
Screamin Eagle CVO Models
Oct 31, 2012 07:45 AM
Hondo65
Jun 14, 2012 10:32 AM
da_big_Guy
Aug 30, 2010 06:16 PM
Cohiba_Joe
Apr 26, 2010 02:52 PM
