Horn Vibration Fixed
Old Apr 26, 2010 | 01:37 PM
iHarley's Avatar
iHarley
Default Horn Vibration Fixed
Photos added see post #11. This is so easy to do.
Read all the bitchin and no solutions, other than relocating the horn, to the flopping around like a spastic poorly Moco design horn mount.
Solution - remove the rubber isolator and chuck it, install in its place a 5/16 - 1/2 thick x 1-1/2 diameter spacer made out of aluminum, steel, hard plastic, whatever just not rubber. I used 5/16” aluminum, made the spacer by cutting out a disk with a 1-1/2” hole saw, then drilling out the center to fit a 5/16” bolt. Put a 5/16” bolt into the back side of the mounting bracket, then new spacer, horn bracket, washer and cap nut.
Problem solved!
Old Apr 26, 2010 | 01:59 PM
Badfinger's Avatar
Badfinger
Gee I wonder why the Moco put that silly rubber isolater in there in the first place ???
Old Apr 26, 2010 | 02:14 PM
n8dc's Avatar
n8dc
Ok who wants to make bets on how long before the horn bracket breaks now ... that rubber was in there for a reason ! Mine shakes like an early morning drunk and I could care less..
Old Apr 26, 2010 | 02:18 PM
harley-jones's Avatar
harley-jones
You might as well go down to the dealer and buy another bracket. I bet you are going to need it before long. Just my opinion!
Old Apr 26, 2010 | 02:20 PM
Gliden's Avatar
Gliden
I just replaced mine. Goes under this skull cover. The dealer said they go through them like water. $40.00 bucks a pop. He also said they have been revised about 6 times the horn. The latest revision is letter "F".......
What I found wierd is it comes with this really no bull shi% black powdercoated hanging bracket for those VSR Buell thingys.....My point is the damn bracket has to be worth 12 bucks in Harley world and Harley puts one in every box!
Why did I have to pay for that??
I just wanted the damn horn not the horn hardware and bracket for Buel bikes....
SoCalRoadGlide's Avatar
SoCalRoadGlide
+1, I doubt the MOCO would go to any extra expense involved in building their bikes unless they can justify it somehow.
Old Apr 26, 2010 | 11:12 PM
thereal142's Avatar
thereal142
Originally Posted by iHarley
First... I did not take photos - sorry. But this is so easy to do.
Problem solved!
You will regret this sooner than later...
Old Apr 27, 2010 | 12:31 AM
hog-doc's Avatar
hog-doc
This must just be the year for "fixing" all the "junk" HD parts that never break!
Old Apr 27, 2010 | 04:17 AM
mike5511's Avatar
mike5511
great fix! I'm gonna replace those pesky air shocks on mine and eliminate all that bouncing when I hit a bump!!!
Old Apr 27, 2010 | 04:38 AM
elPrez's Avatar
elPrez
Exclamation
Great idea...I may replace my tires with wagon wheels
